Diffference between Deere 210 and 310 backhoe
Biggest Jim
01-12-2005 07:51:43
I am loking for a good tight 310 and found a 210 at an auction coming up. Will a 210 do the work of a 310? how much difference in the two tractors, size, power etc. Thanks
Allan/NCA
01-12-2005 19:49:27
 Re: Diffference between Deere 210 and 310 backhoe in reply to Biggest Jim, 01-12-2005 07:51:43
The main complaint was that they didn't have the hp or the hydraulics of the 310 and lot operators just didn't like the loss of production. That was also the problem with the later model 300, just not as productive. Allan
Jonathan in MA
01-12-2005 14:49:48
Its a 210c but what model 310 is it your comparing to ?? Early 210C's had flame-cut loader booms that tented to bend. The newer ones are made from fabricated tubes which is stronger. They also don't have balancer shafts in the engine and tend to break mufflers on a regular basis due to the vibration at idle. Check the reverser oil to see if it smells burnt.. Make sure it moves ok forward and reverse...should overpower the brakes in 1st gear .. If its 4 wheel drive, check the front king pins..lift the front end of the ground and watch if the steering knuckles drop and the front wheels hang at a different angle. If they are worn past the bearing races, it may need an axle housing ..$$$$$$$$.. They arent too bad a machine...if not abused heavily in a former life. I'm not sure where youre located , but around here road salt is quite heavily used in the winter and the fenders on those don't hold up well.. Deere fenders are very expensive for those machines...
