Buy John Deere 6300 4x4 with loader ?
Papa D
01-11-2005 19:04:22
First time JD buyer looking to buy a JD 6300 4x4 with loader. Can anyone give me any pros or cons on this tractor.
Josh in Indiana
01-12-2005 16:02:28
 Re: Buy John Deere 6300 4x4 with loader ? in reply to Papa D, 01-11-2005 19:04:22
Papa D, how are ya this evening? We have a 6400 with a 640 loader on it. Its a pretty good combination. We have had it about 10 years and the only problems we have had was a alternator go bad and a alternator belt go bad. The sight lines for the loader are not as good as that of a 4020 but the lifting capacity is higher. Over all I really dont have much bad to say about them, Post back or email me with more specific questions if you would like.
Good Luck,
Josh in Indiana
Papa D
01-12-2005 18:10:45
 Re: Buy John Deere 6300 4x4 with loader ? in reply to Josh in Indiana, 01-12-2005 16:02:28
Josh, thanks for the info. Just wanted to make sure there were no problems surfacing on this model tractor before I spend the money. You can expect to change alternators and belts. If thats all that is good. I will just be bushhogging 20 acres and piling trees and tree limbs with this tractor. Thanks again for your help. If you find a good tractor this size please let me know.
Josh in Indiana
01-12-2005 22:33:53
 Re: Buy John Deere 6300 4x4 with loader ? in reply to Papa D, 01-12-2005 18:10:45
Papa D, We also use ours for bush hoging as well as brush clearing. We went out and bought a grapple for our bucket. Its a miracle worker when it comes to stacking brush as you can take big trees and you dont have to worry about losing it when your taking it to the pile. Depending on what your looking at you can also install a joystick with that loader. Those are a nice feature.
Good luck,
Josh in Indiana
P.s. I called home and had dad pull the service records for our machine. I forgot to mention that we had a spring break inside the tranny once. It was simple enough that we didnt have to split the tractor. Deere said it was a freak thing as they had not seen any that had this problem before so I wouldnt worry about it.
P.s.s If you are in the mid west you may want to subscribe to a magazine such as farmers exchange or fastline. Those are good sources for newer tractors like that. Machinefinder.com is another good place to look too
Papa D
01-13-2005 05:28:35
 Re: Buy John Deere 6300 4x4 with loader ? in reply to Josh in Indiana, 01-12-2005 22:33:53
The grapple sounds like a great idea. I will certainly check in to that one. I will be shopping around for one of these tractors. Everything I have found says they are good ones.
Thanks a million for your help.
