1948 John Deere A mag questions
Gary in TX
01-11-2005 10:42:56
Hi guys, I acquired a 48 model John Deere A this past weekend for $300.00. Was told that it was running and they put another mag on it and it has not run since. I'm thinking since I was told they paid only $35.00 for the mag they got one in need of rebuilding or at least points and condensor??? I have not done anything with it as of yet and may be a ways down the road before starting on. Where would yall start on locateing the problem. Motor is loose and I can hear the mag trip when when we turn the flywheel by hand. Could it just be 180 degrees out of time. I mean the mag can only go on one of two ways and then adjustments? Tractor is in pretty good condition, I remembered it looking worse than it does when we looked at it the first time. Also this one has a single front wheel on it. First A that I have seen in person that did, seen pictures of others of course. Thanks!
John T
01-11-2005 11:58:39
 Re: 1948 John Deere A mag questions in reply to Gary in TX, 01-11-2005 10:42:56
Good afternoon Gary, I hope its just a minor mag problem, and to answer your question YES IT COULD JUST BE 180 OUT (see below) but we have to know what make n model mag you have to go real far in diagnostics over the net. If its a Wico Model C or X Series, they are easier to get parts for and work on than some others, but I will give you a lil preliminary advice in the meantime.
1) You mention 180 out of time, but that makes a difference depending upon what Mag you have. IFFFFF FFF its a non reduction drive (direct drive) gear mag (turns same RPM as crankshaft and governor) such as the Wico C or X Models, they fire at BOTH TDC's, Power and Exhaust, and consequently, if they are installed 180 out (mag drive fits into governor either way), its possible to make them run SIMPLY by reversing the top n bototm plug wire locations, or remove the mag and rotate either its drive or the flywheel 180 and stick em back in.
2) They were originaly wired top cap tower to left cylinder and bottom to right on the Wicos and others, but they may have gotten installed reversed over the years and the wires swapped.
3) Heres what you need to do first:
a) See if shes firign at all when she snaps.
b) Then make sure shes firing in time, cuz if its NOT a direct drive mag (like the Wico AP) they have to be instaled correct (not 180 out) and simple wire reversal alone will NOT make them run. 4a) To see if she firing at all, remove a plug and have its wire atached and its side grounded to the tractor frame, and every other time the mag snaps (if its a direct drive mag) a blue spark ought to jump the plugs gap. Orrrrr , simply remove the plug wire and have its end to within 1/8 away from frame and every other mag snap it should spark. Does it????? ???
4b) Now if she is firing, remove the plugs so you can feel when shes coming up on the Compression Power Stroke, cuz thats when shes building compression out the plug hole,,,,, then when say the left (flywheel side) No. 1 piston is at TDC on Compression, the plug wire to that plug MUST FIRE AT TDC and then 180 of flywheel rotation later,,,the right side plug should fire cuz then its at the TDC of its Compression Power Stroke.
NOTE: If all is correct and in time, she ought to snap as the Flywheels Left Hand Impulse timing mark passes by the flat mark on the tractor at 3 o clock position, as thats when the left piston is at TDC.
5) REMEMBER , if its a direct drive mag like the Wico C or X and it is firing but just the opposite as above, a wire swap or mag removal and 180 turn of its drive or the flywheel can make em run EVEN IF 180 OUT.
6) NOTE if its 180 out (or wires reversed) she may pop n bang n backfire and/or kick the flywheel backwards if she has gas and is sparking.
SOOOOO OO SEE IF ITS FIRING AT ALL,,,,, ,,WHAT MAG IT IS,,,,, ,,,AD THEN IF IT IS FIRING, IF ITS IN TIME (in which case if 180 out a wire reversal may cure if its a Wico C or X Mag)
TROUBLESHOOTING
Some of the very first things you need are good plugs !!!!! ! If yours are fouled or oiled up or carbon coated FIRST TRY NEW PLUGS. Also you need good wire core wires that arent bad or shorting or burned or open.
NEXT the most often common cause of a mag not firing ASSUMING SHE IS SNAPPING OVER WELL is bad points. Remove the cap and make sure they are gapped proper and opening n cloising AND ARE NOT GRAY OXIDE COATED OR CARBONED UP OR BURNED OR PITTED AND REPLACE IF NECESSARY.
NEXT if its a Wico X and has an external kill switch stud/post, make sure the post or any wires to it ARE NOT SHORTED TO GROUND as that kills the spark.
NEXT I am next gonna cut n paste a generic mag troubleshootign procedure that may suffice until you tell us what mag you have,,,,, and if its firing at all,,,,, and if its in time or 180 out etc. and we will proceed later from there.
GENERIC TROUBLESHOOTING FOR A WICO X AND MOST APPLIES TO THE WICO C ALSO
The very first thing I would suspect causing a weak spark in a Wico X Magneto are points that are either gray oxide coated or burned or pitted or carboned up or not gapped proper to 0.015 on high cam.
TROUBLESHOOTING A WEAK WICO X MAG SPARK
1) If the points look good but only gray oxide coated, you might try to non abrasively clean/buff/polish them to get that oxide removed and then set the gap at 0.015 and see how she does ????? Bad points are a primary cause of a weak mag spark. 2) If the points are burned or pitted or badly carboned up, a dressing with a point file may get her running better temporarily, however, once they get in that shape or you abrasively remove the silvery point coating, they wont last long. IF THEY ARE IN THAT CONDITION REPLACE THEM.
3) DOES SHE MAKE A GOOD LOUD SHARP SNAP EACH 180 OF CRANK ROTATION OR A FAINT DULL CLUNK???? If she has a weak starting spark but she runs fine if pull started, the mags impulse spring may be weak which can cause a real weak spark at cranking RPM but still produce a good spark over 250 RPM when the spring wind n trip impulse assembly is disabled.
4) The next thing I might suspect is the spark plugs. If they appear fouled or are carboned up TRY A NEW SET OF PLUGS. To see if its more a plug or a mag problem,,,,, ,,remove the plugs but thave their wires attached and the sides grounded and crank the engine over AND VERIFY BOTH PLUGS PRODUCE A GOOD VISIBLE BLUE (not faint thin wimpy yellow) spark????? ??? IF NOT, remove the plugs but just have the plug wire ends fixed 1/8 inch from tractor iron, crank her over and see if the sparks good there????? ? If its good at the wire ends BUT NOT the plugs, suspect bad plugs.
REGARDLESS IF THE PLUGS ARE OLD OR APPEAR FOULED OR CARBONED UP, TRY A NEW SET OF PLUG N SEE WHAT THE SPARK LOOKS LIKE????? ????? ????
5) If the mag snaps good n sharp n loud and the points are good but even the plug wire tests show a weak or yellow spark,,,,, ,,,its time to check the cap n rotor n wires !!!!! !!!! To check the spark independantly of the cap or rotor or wires, remove the cap and bend a wire or paper clip etc attached to the mags metal side frame to within 1/8 inch away from the coils side output button/terminal. The each time shes rotated and the mag snaps THERE OUGHT TO BE A GOOD BLUE SPARK THERE????? ??? If so there BUT NOT out the wires, suspect a cap or rotor or plug wire problem. MAKE SURE THE LIL SPRINGY CAP CONTACTOR MAKES GOOD CONTACT AGAINST A CLEAN COIL SIDE OUTPUT BUTTON/TERMINAL AND THE ROTOR !!!!! !!! If not tight or the contact points are burned or carboned up, that can weaken the spark.
ALSO MAKE SURE THE CAP IS CLEAN N MOISTURE N OIL N DUST FREE AND NO CRACKS OR CARBON TRACES which can weaken a spark.
ANOTHER THING TO CHECK IS MAKE SURE THERE ARE NO SHORTS IN THE SIDE OUT KILL SWITCH STUD (where it passes through mags case if it has one) OR ANY WIRES ATTACHED TO IT ARE SHORTED EITHER INTERNALLY OR EXTERNALLY
6) Another suspect is the condensor or if its not wired correct and no shorts. It can still spark to some degree with maybe a weak or open condensor,,,,, ,,,,BUT NOT THE GOOD STRONG BLUE SPARK YOU NEED. If you susect its open or leaky REPLACE IT N SEE IF THE SPARK IMPROVES !!!!!
7) NOWWWWW WW if all the above is good,,,,, ,points are good,,,,, , good loud sharp snap,,,,, ,,cap n rotor n springy contact and surfaces are all good,,,,, ,,,wires n plugs are good and/or new plugs,,,,, ,,,condensor is good BUT SHE STILL HAS A WEAK SPARK even direct off the coils side button under the cap NEXT THINGS I SUSPECT ARE A WEAK ROTOR MAGNET OR RUSTED OR CORRODED ROTOR OR THE LAMINATIONS.
7) FINALLY, if alllll ll the above is good, the rotors not rusted up,,,I may finally suspect a bad coil.
THERES PLENTY MORE, BUT THIS OUGHT TO BE ENOUGH TO GET YOU A START THEN POST BACK YOUR FINDINGS AND ANY MORE QUESTIONS N WE WILL GO FROM THERE You may just need a new set of points and spark plugs and BE SURE AND USE GOOD WIRE CORE NOT CARBON SUPPRESSOR WIRES !!!!! !!!!!
Hopefully there will be other thoughts n opinions offered and we will get you a good spark.
God Bless ya, post back your findings, what mag you have, if its in time, and any quetions or feel free to call mE at 812-824-4608. John T Nordhoff in Indiana Let me know
rob nickel
01-15-2005 01:40:03
 Re: 1948 John Deere A mag questions in reply to John T, 01-11-2005 11:58:39
Another possible problem you might be having that's really simple to diagnose and repair is that the stud on your backing plate which the point's ride on could be bent or loose? If it is, like the one on my own Wico C is right now, there's no way to set the point's properly, even though they may well appear to be set right? The gap will change as soon as you crank the engine, throwing your timing out of whack and of course keeping your machine from running. Just a thought, and I hope you find your problem easily solved?
chrisfromsolitude
01-11-2005 11:03:35
First thing I would do is make sure you are getting spark from the mag then trace it to the plugs. There is also a certain procedure for mounting the mag but I can't rember it off hand. May file the points then check the spark. This isn't much but it will get you started.
