420 T-O-M Seal Question
Bguy
01-11-2005 08:52:23
I have a 420W that is in really good condition. The dual T-O-M, lift and everything works great but it has a couple of leaks that I am going to address before I paint and etc. I have all of the manuals but they mainly show how to do a complete rebuild. My question is: do you have to remove and tear down the valve housing, front cover and quadrant to replace the seals on the shafts? Does the control shaft pull out after removing the quadrant or do you have to replace it from the inside? I have never tore into one of these so I hate to tear into and mess up a good working system but it leaks quite a bit around these control shafts. The rockshafts weep just a little so I going to leave them alone.
Henry J
01-11-2005 17:43:08
 Re: 420 T-O-M Seal Question in reply to Bguy, 01-11-2005 08:52:23
BGuy
Since you are gonna take it apart, if it was mine, I would check and see if the rock shaft housing has been upgraded/replaced with the one with bushings in it. Mine dried right up with bushings on just the dual side and seals all around.
Oh this is gonna be fun :-)
buickanddeere
01-11-2005 17:15:27
If the seals have failed due to shaft/housing wear. The upgrade to bushings used in the late 30 series and 1010 can be done.
andy b.
01-11-2005 16:39:38
i had to replace the control shaft seal and rockshaft seals on my 40U last year. it is only a single TOM, but the process is similar. you must remove the quadrant and front TOM cover. there are some linkages that must be removed before the control shaft will pull out. MAKE SURE TO NOTE EXACTLY HOW THESE LINKAGES FIT TOGETHER. the pictures in the manual don't show everything clearly and you can get things hooked up kind of backwards if you're not careful.
my system worked fine too except for the leaks. as long as you keep everything as clean as possible and put it back together just like it came apart, you shouldn't have any problems. as you noted, the manual pretty much covers a total rebuild. i just followed the steps for what i needed to do (control shaft seal and rockshaft seals) and didn't have any problems.
oh, one other note, it really is easier to work on if the TOM unit is removed from the tractor. it looks like you can do it with the TOM still in place, but the front cover may be a tight fit coming off and going on.
andy b.
Bguy
01-11-2005 16:05:05
OK, Thanks for the info. I"ll pull it off and fix it right. I have the seals on order from JD.
Wayne in Tn.
01-11-2005 15:08:59
B Guy, Yep you have to remove that front housing in order to replace those little seals. If you pull the front one out, the lever will fall off inside the case. Also that quadrant has to be "timed" for the correct lever travel when you put it back together. Deere now has real seals to replace the old leather or cork type seal.
Henry J
01-11-2005 15:59:01
 Re: 420 T-O-M Seal Question in reply to Wayne in Tn., 01-11-2005 15:08:59
You also can not pull the back shaft out because it is pinned on the crank inside.
