axel bearings 46 B
Ken Tabor
01-11-2005 07:31:53
OK, I got the axles out of the B, Want to replace the inner and outer bearings and seals. Am looking for suggestions on technique or tools needed to get the bearing cones out of the casting.
Ken
Walter Squires
01-11-2005 08:07:12
 Re: axel bearings 46 B in reply to Ken Tabor, 01-11-2005 07:31:53
The best way I have found to get cones out is to weld a bead around the inside of the cone, let it cool and it will fall out.
Good Luck, Walter Squires
xxragman
01-12-2005 19:18:33
 Re: axel bearings 46 B in reply to Walter Squires, 01-11-2005 08:07:12
DO it like walter said. I did mine this way a couple of mounths ago. works good but be careful not to weld on casting.
