JD 420 fluids
billde
01-10-2005 18:57:40
brought one of my two "new" 420's home last night! what and how much fluid is used in the hyd/trans, and final drives? Waiting on a service manual, but weather is decent so I thought I would go ahead and change all fuids before it turns cold again. Thanks!
Johnnyputt
01-11-2005 15:02:30
 Re: JD 420 fluids in reply to billde, 01-10-2005 18:57:40
third party image
Here"s a link to my website which has the lub chart right out of the service manual.
buickanddeere
01-11-2005 10:40:22
One of the resident experts here suggested marine gearbox Sae 140 which is GL4 I think? The idea is it's an extreme pressure lube to protect that ring and pinion. And formulated not to turn corrosive when mixed with water like sulphur based oil additives.
bgiese
01-11-2005 06:01:51
I believe that the transmission is 80-90w along with the final drives,TOM is 10w, steering gear non power steering is 140w gear oil engine oil depends on the temp, pto shaft is 80w-90w this is off the top of my head so could be a little off
Henry J
01-10-2005 19:59:22
Bill
I would recommend first the operators manual. It costs a pittance in comparison and has all the user info.
Personally I use 85W140 in the trans because of the hypoid gears in the differential. That is GL 5 so a lot of different thinkers will recommend something like GL one becaue of the theory of it is best for straight cut gears. Usually on the gear oil you either fill the trans up to the top of the fill plug, and the finals to the top of the fill hole - you did not mention the model and I am only familiar with the W.
The book says 10 W non detergent in the touch o matic. tom's usually have a petcock that you open and fill them until the oil runs out the petcock.
CPeter
01-11-2005 05:42:16
 Re: JD 420 fluids in reply to Henry J, 01-10-2005 19:59:22
Like Henry J says, that is NON detergent oil in the TOM. The fill plug for the transmission and rear end is on the right side of the tranny just by your heel. Fill to the top.
billde
01-11-2005 08:20:44
 Re: JD 420 fluids in reply to CPeter, 01-11-2005 05:42:16
figured everything out except, where do I drain TOM? Thanks
Henry J
01-11-2005 09:00:18
 Re: JD 420 fluids in reply to billde, 01-11-2005 08:20:44
Look around on the back of it to the left of the check for full cock and you should see a plug on the housing for draining.
Rockbasss
01-11-2005 08:18:49
I recently ask a question about oils for my JD '58 420u. What I got out of it was this
Steering Housing - GL1 140 or if it is empty use Corn Head Grease
Final Drive - GL1 140
Transmission-Differential - GL1 140
Power Shaft - GL1 140
Crankcase - SAE 10W-30 non-detergent or 10w or 30w non-detergent motor oil (depending on season)
Touch-O-Matic - 10w non-detergent motor oil
TomL
01-11-2005 12:06:10
 Re: JD 420 fluids in reply to Rockbasss, 01-11-2005 08:18:49
Rockbasss,
What is "Corn Head grease"? I have a 420T that I put 90W-GL1 in the lower steering box and it leaks continuously-messy.
Henry J
01-12-2005 06:06:27
 Re: JD 420 fluids in reply to TomL, 01-11-2005 12:06:10
Tom
I think that Corn Head Grease is a trade name that JD uses. That is what it says on the side of the tube and the tube says it is for gear boxes like on combine heads. It is a light grade of grease and seems to be quite sticky. I have never had any of that grease "leak" out. I use it in the gear boxes that have a vertical shaft like the ones on the steering on the Dubuque.
I sure am glad someone suggested this stuff to me. It is hard to hold oil in a reservoir that has a decades old shaft running through it. But I did put new seals in the boxes that I have the stuff in.
TomL
01-12-2005 12:59:14
 Re: JD 420 fluids in reply to Henry J, 01-12-2005 06:06:27
HenryJ,
My local JD dealer does not have the corn head grease. He sold me a tube of JD HD Moly grease, 3%Moly, and said it would work fine. Do you think it is ok or should I go to another dealer to find the Corn Head grease? Tom
rick in sc
01-12-2005 19:38:51
 Re: JD 420 fluids in reply to TomL, 01-12-2005 12:59:14
TomL, I've been using "00" Snapper lawn mower grease in my 420T. It seems to work good and so far does not leak out.
TomL
01-13-2005 10:04:58
 Re: JD 420 fluids in reply to rick in sc, 01-12-2005 19:38:51
Thanks Rick in SC, What part of SC? I am in upstate. I'm not concerned with grease leaking out, just adequate lub for the gearboxes. Did you use in upper and lower gearboxes?
Tom
rick in sc
01-14-2005 03:36:21
 Re: JD 420 fluids in reply to TomL, 01-13-2005 10:04:58
TomL,I'm in the upstate too. Live near Donalds in Abbeville Co. Have only used it in the gearbox. My pedestal isn't leaking yet. Thought about mixing some STP with it to make it a little slicker so it would steer easier, but haven't done it yet.Good luck!!
Rockbasss
01-11-2005 22:40:49
I believe it was Henry J. that told me about Corn Head grease. I was told that it is a green color so if/when it leaks out it isn't so noticeable and messy. It should be available at your JD dealer. Just a side note, I used 90W-GL1 in the 420U when everyone was saying to use the 85w140.
