I need a magic pill !!
Plant Doctor
01-10-2005 16:28:09
My neighbor had two forklifts, one with a bad engine the other with a bad trans. He had his workers disassemble them and try to mix and match parts to make one good one from the two. Long story short, they left the two forklifts lay outside apart in the weather for almost two years. He asked me to take a look at them and see if I could get one good one put together without breaking the bank. 1 1/2 weeks later I had one assembled and in operating order. But here is the problem, while the two forklift were outside in the weather apart, water got into all the hydraulics. I used air to blow out all the lines, I drained the hydraulic oil tank several times and the oil returning to the hydraulic tank is still milky looking. I filled the oil tank and disconneted the hydraulic return line from the tank and put it into an drum. I then started the engine and worked all the hydraulic cylinders, power steering, and rotory dump and kept adding oil to the tank. After going through about 25 gals of oil I put the return line back on the oil tank and worked the forklift for maybe 20 minutes. The oil returning to the tank still looks milky. What can I do? Any suggestions will greatly appreciated.
johndeereman
01-11-2005 07:56:58
 Re: I need a magic pill !! in reply to Plant Doctor, 01-10-2005 16:28:09
are you letting it sit a while before you look at the oil? if you are looking at it right away it might look milky it has air in the oil this is normal im not sure if it works on hyd. but when we get water in the rear of a tractor we fill it with diesel feul run it for a while drain and fill with oil hope this helps.
