720D No 4th 6th Gear
Hoby
01-10-2005 13:58:59
I haven"t been able to shift into 4th or 6th gear for quite sometime, so thought I would try to fix the problem. Go trany cover off, there"s alot stuff in there. Looked things over, read through shop manual. Done the above three times and still don"t have a clue. 4th stop shifting before 6th did, probly several months. Gears are ok, I"m sure it"s a shifter problem, but don"t know what to do. Need some help in some really simple terms. Thanks guys.
Mike M
01-10-2005 15:34:04
 Re: 720D No 4th 6th Gear in reply to Hoby, 01-10-2005 13:58:59
Just want to add to what clooney said. You can take a crow bar and manually shift that trans. into every gear--one at a time---then back to neutral to see how it works. You should need to also move the interlock inside of the shifter before it will move or it is not working right. Turning the belt pulley by hand will help line up the gears as you shift them. Do this all by hand with a bar,and of course have the engine shut off.
Clooney
01-10-2005 14:25:40
third party image
Hoby, I'm pretty sure I know what ails your trans.. Over the years I have repaired quite a few with a locked out 4th/6th shifter interlock.. I just wish I could explain the procedure. Basically the interlock (parts shown) wear & don�t allow the shifter to release the interlock & pin (16).. You will probably find wear on pin 18 due to a rounded off end.. That pin is as hard as snails nuts so won�t allow you to re-drill the set screw hole..
I guess the thing to do is look that interlock over VERY CAREFULY & play with it until you FULLY understand how it functions & unlocks.. Then see if you can pry in the shift lever slot & watch it unlock as you pry the shifter over..
I wish I could explain the repair to you but it is like trying to explain to someone how to tie a shoe lace. Very easy to do but difficult to explain to someone..
Look it over, see how it works,, then post back or E-mail with questions (I know you will have some)..
If it is that pin 18 just buy a new one if you can or I have rotated them so an unworn edge is down, then Lock-Tite it in place & re-tighten the set screw (the set screw will not go in the hole again if you rotate it that's why the Loc-Tite is used)..
If by chance your problem isn�t the interlock just throw this post in the trash..
Clooney
