Wes, first make sure nothing from the hand lever to the governor is moving on it's own.. Make sure all the bolts are tight that hold the lever pivots & lever to the rod.. If something between the hand lever & the governor changes position it will never return to the same engine speed. If all ok there make sure the cotter pin that holds the linkage to the carb�s top lever isn�t hitting or binding on the carb casting (common problem).. Make sure ALL the throttle rods are not hitting or contacting ANYTHING between the governor & carb.. Make sure the carb�s throttle shaft bushings aren�t loose or leaking.. Make sure the carbs base gasket isn�t leaking. Make sure the carb is tight� Make sure the intake manifold doesn�t have any vacuum leaks ( use an un-lit propane torch) to probe all the carb & manifold joints to see if you get an engine speed change).. If the carb, throttle linkage, & vacuum leaks all seem a/ok then possibly you have a magneto or distributor problem that is not allowing a good precise control of the spark timing (just a thought).. Your problem could be caused by an awful lot of smaller things but most are simple things so you really need to get creative & check EVERYTHING that COULD cause your problem.. Don�t assume anything or you could easily miss the cause.. My guess is it will be something simple.. Clooney
