A stalls after start
Derbynut
01-10-2005 13:10:40
I have a '41 A that stalls seconds after starting. I can then resart just to have it stall again. I can sometimes catch it just before stalling by closing the choke but only for a few seconds and then it stalls again. Seems an obvious fuel starvation. There is a good fuel supply from the tank and into the carburetor. I have rebuilt the carburetor but must say this was my first tractor carburetor rebuild but have rebuilt scores of auto carburetors and wrenched on cars for over 35 years. First thought seem to be the float level but I have checked and rechecked and I'm sure it's correct. I know I'm missing something but what?
johndeereman
01-11-2005 08:03:51
 Re: A stalls after start in reply to Derbynut, 01-10-2005 13:10:40
my b did thatit was sucking air get it started and spray either round the carb one spot at a time see if engine revs up if so that is where the leak is.
e egli
01-11-2005 05:22:42
check points for white pits. you might not be getting hot enough spark. my a did the same thing.
Derbynut
01-15-2005 13:10:31
 Re: A stalls after start in reply to e egli, 01-11-2005 05:22:42
It's fixed! What a good lesson in "think outside the box"! Everything about it suggested it was starving for fuel but no restriction was found. After the comment about weak spark I thought why not try plugs, who knows? Two new plugs installed and it fired right off and ran just fine. I do apreciate all who helped with the well thought out comments. I'm sure I'll be back one day with another question. Thanks again "everyone."
John T
01-10-2005 20:03:10
Derby, you say it has a good fuel supply TO THE CARB, but that doesnt necessarily mean it has a good flow to and throught the carbs side inlet strainer and needle n seat and the float assembly is oaky!!!!!
To check the flow through the carbs side inlet strainer and needle valve n seat, turn the gas on and open the carb bowls lower drain cock/plug and insure a good steady stream of gas flow approx. 1/16 of an inch a couple minutes. If flow is good there, the needle valve n seat are free although the float level may be off but yoiu say thats okay.
You say choking helps, but then it stalls again?? What I would do next is to remove the air inlet and make sure THE CHOKE BUTTERFLY PLATE IS TIGHT ON ITS SHAFT,,,,, ,IT CLOSES FULLY N STAYS CLOSE IF THE ROD IS PULLED,,,,, ,,AND GOES N STAYS RELATIVE TO WHERE THE EXTERNAL CHOKE ROD IS AT ????? ???
I have had tractors with the lil coil springy under the external choke assembly (like Bills pic above) either not connected right or broke etc such that even if the choke rod is pulled, THEY REALLY WERENT BEING CHOKED. Even if she dont have that spring assembly, the way to tell for sure what the butterfly plate is doing is to remove the air inlet n operate the choke and seeeee eeeee whats happening.
Next, have you done much adjusting on the carbs top load n idle needles??? The initial rough in adjustemnt is closed down then 1 out for load and 2 for the idle needles.
Next, is the top throttle slow idle stop bumping up against the vertical spring when you pull the throttle back??? and have you adjusted it and the idle???
Finally, as far as fuel is concerned, are there any vacuum leaks like around the carbs base or throttle shaft bushuings which can allow air to be sucked in and lean the mixture (which choking can help).
As far as ignition, what type is it and are both plugs producing a good hot blue spark???
Summary: Check the choke assembly and butterfly plate,,,,, ,,adjust the carb,,,,, check the fuel flow out the carbs bottom drain (see above),,,,, ,,insure you have fresh clean water free gas and insure the air cleaner bowl isnt full of water?????
Let us know, good luck n God Bless
John T in Indiana
Clooney
01-10-2005 14:42:16
third party image
Derbynut, you could have any number of problems form a carb bowl that is low on fuel to a magneto/distributor that has initial problems, to a basic carburetor problem..
At first guess I would lean toward your choke shaft spring (that is if your carb has one)..
If that spring isn�t installed correctly, is weak, or the attachments are not in the correct location it will allow the choke plate to pull open just after starting & the fuel air mixture will go lean & that means a nasty stall.. I guess it�s worth a look/see anyhow..
Clooney
