FarmerWannabe, I haven't installed a Gresen Hydraulic Valve in a long time & then it was a single.. Does your valve have an (IN) & (OUT) or [conversion port] on it?.. I believe the last one I installed I had to install a power beyond bushing in the conversion port. That schematic you furnished isn�t real clear on the (OUT) port but it looks like it would be (T).. Basically your valve has to be converted to an open center valve (at least most do),, & also converted to a (power beyond) valve --- then pressure from the tractor�s hydraulic pump enters the valve at the valve�s (IN) port,, then the valve�s (OUT) port goes on back to the tractor�s power-trol pressure in line.. That way both the installed valve & the tractor�s power-trol will both function.. Did your valve come with an open center conversion bushing? Is your valve marked (IN),, (OUT),, (A),,(B)? Obviously the (A) & (B) would go to the loader arm rams & a second set of (A) & (B) would go to the loader bucket rams.. If what I said above doesn�t match your valve or situation you should probably call the valve company�s tec help line.. On your tractor�s power-trol dropping? NO!.. it will work just like factory as it doesn�t use continuous hydraulic pressure to hold it up.. The rear unit stays in position by the rear lever valve shutting & holding the position with trapped oil.. Clooney
