JD 1530 smoking on one cylinder
Charlie1530
01-10-2005 11:34:39
I have a JD1530 diesel that will smoke pretty heavily from its middle cylinder when first started. (I pulled off the exhaust manfold so that I could see which cylinder was smoking.) It is kind of light colored or light grey smoke. It seems to keep doing this even after running for 5 or 10 minutes. The other cylinders will start smokey but clear up in less than a minute.
If I turn off the tractor after this initial 5 or 10 minutes of running, wait a couple of minutes and then restart it all cylinders run clear! I had it sitting in a heated garage so the engine should have been at about 60 degrees when first started.
I have replaced the injectors but made no difference. I also checked the compression, one of the good cylinders read about 270lbs and the other 2 cylinders (one bad and one good) both measure about 260lbs. The tech manual said that they should be a min. of 300lbs but I am in Colorado at 7000 feet above sea level so I didn"t think the compression was too bad.
There doesn"t seem to be too much left that could be a problem on a diesel engine. Could the timing on the injection pump (roto-diesel) cause anything like this?
This is my first diesel tractor so I would appreciate any comments or suggestions. Thanks.
