Cutting/removing ruber tires
Courtland
01-10-2005 10:33:49
Best way to cut and or remove half rotted "rear" tractor tires from the rim? Rims & tires still mounted on tractor.
DAVE NE IOWA
01-10-2005 19:04:11
 Re: Cutting/removing ruber tires in reply to Courtland, 01-10-2005 10:33:49
I'm fortunate enough to have a 14 inch gas powered mason saw, takes longer to fuel it up than to cut the tires off. Maybe you have a buddy with one. Dave NE IOWA
ChuckW
01-10-2005 14:57:03
I found a grinder with a thin blade worked the best, a little messy and be careful with it, but it cut through the rib with little or no kickback. A sawsal had a jerking action didn't do good in bead.
Dave Sherburne, NY
01-10-2005 14:25:31
Just did that, tried a utility knife it cut real easy, Cut about 2" from the rim, and took the tire off , then you have to cut thru the bead where the metal is .
Duane Larson
01-10-2005 13:36:40
Courtland,
I agree with the sawzall - and after you get as much of the tire removed as you can, get yourself an air-powered needle descaler and just peal the rest of the rust/rubber off the wheel. Best tool I have found for this job, bar none. Northern Tools have them for about $40. Also pickup some ear protection as you will need it!
Henry J
01-10-2005 13:29:31
The saws all it the way to go to save the rims.
However if the tires are really rusted to the rims, I would recommend breaking them loose first. I have been able to do this with a 2X8 on the tire and driving the truck up on the ramp made by the plank with no rim damage.
Mike M
01-10-2005 12:53:51
I have done this before to save some rims that had old hard tires on them. When I went to use a tire iron to bring them up over the rim it just wanted to bend. I used a saws all on them only tough spot is the steel in the bead area.
billde
01-10-2005 10:57:52
If you have or can borrow a sawzall they make the job much easier. Of course this may be a good excuse to buy a cordless sawzall!
Johnbob
01-10-2005 17:04:29
 Re: Cutting/removing ruber tires in reply to billde, 01-10-2005 10:57:52
I use the top side of the blade on a chainsaw and cut close to the bead.Then use a grinder to cut the bead.
