4430 PFWD/148 OR 158 LOADER
SAMMY
01-10-2005 09:47:10
Will a 148 or 158 John Deere loader work on a 4430 tractor with power front wheel drive? Is there enough clearance with the front end ocsillated all the way one direction and the loader completely down? Thanks for your replay, Sammy.
JD Jack
01-10-2005 16:49:31
 Re: 4430 PFWD/148 OR 158 LOADER in reply to SAMMY, 01-10-2005 09:47:10
It might just work with the wheels out wide enough. A neighbor of mine had a JD 48 on a 4230 with front assist.
TIMAR
01-10-2005 10:20:01
It won"t work unless you put the front tires out as far as possible, and then it"s iffy. A better fit would be a 265 or 740. 265"s are the same age as a 148 or 158 but are self-leveling. They are not built as heavy as a 740, but if it has not been used like a dozer, they hold up good.
