420w drawbar
bgiese
01-10-2005 04:32:16
was wondering if anyone had a factory drawbar that I could get the measurements from as far as length,width,depth, placement of holes and size of holes. thanks for the help
bgiese
01-10-2005 17:05:07
 Re: 420w drawbar in reply to bgiese, 01-10-2005 04:32:16
what I"m looking for is the dimensions of the drawbar I believe it is 2 inches wide 2 inch thick and around 43 inches long also the hole placement I can get flat stock from work in varying hardnesses and mill the holes out, also would like to know the grade of steel that a factory drawbar is made from thanks again
Mark57_420
01-10-2005 04:57:40
Do you want it "correct"? I could give you the dimensions for the drawbar from a 420T tonight, but it is different than the 420W. Are you just wanting to identify the correct one, or are you wanting to make one? Should be a pretty common part at some of the parts dealers, I would think.
ET
01-10-2005 04:37:49
If its the same as a 40w drawbar I could give you the measurements when I get home tonight.
ET
01-10-2005 14:40:49
 Re: 420w drawbar in reply to ET, 01-10-2005 04:37:49
I just checked my parts books an a 40w and a 420w drawbar are not the same.
