FarmerWannabe, your 50 has a hydraulic pump that makes oil flow any time it�s engaged so you need an �open center� valve as that will allow return of the oil that flows to it back to the pressure inlet on your factory Power-Trol.. A closed center valve is for a newer tractor with an on demand pump.. If you put a closed center valve on your tractor it will deadhead the pump & cause problems (most valves sold today can be configured to go either way with the addition of a pipe plug in the open center port)
Power beyond can be used a few different ways� On your tractor with the open center hydraulics you would just plumb the next valve in line by providing pressure to it from the return port on your first valve.. Closed center does it by tapping hydraulic pressure from any point in the pressure line then returning directly to the sump (I won�t elaborate here as it will add confusion) I don�t have your valve schematic here but basically you need to cut into your tractor�s hydraulic pressure line & plumb that into your monoblock valve�s �pressure in� port.. The center port or power beyond port would then plumb back into the tractor�s line going back to pressurize the factory power-trol.. OR stated simply, cut the pressure line coming out of the tractor�s pump,, then run that line into your monoblock�s �pressure in port�,,, then run the line coming out of your monoblock�s �center return port� to the cut line part going back to the power-trol .. That way the factory power-trol will still operate.. If you just return the monoblock�s center port to the sump (or return line) there will be no pressure to the factory power-trol�s pressure line & it won�t function.. What you are doing with the above is just running the tractor�s factory hydraulic pressure line through your monoblock valve when it�s in the rest position.. Then when you pull or push the monoblock valve lever it cuts off the pressure flow to the tractor�s power-trol & diverts that pressure/flow to one of the monoblock�s outlet ports.. I don�t know if this helped or confused you more so post back with any questions.. Clooney
