Rusty B, there are 3 different areas those B�s tend to leak Power-Trol oil into the rear gear oil.. The 1st is through the PTO inner pump seal---If it is leaking there the P/T oil will tend to leak out as long as the PTO is spinning whether or not the P/T lift is being used.. It takes much longer to leak if the pump isn�t making pressure though.. The 2nd is through the rockshaft lift cylinder to rear housing gasket.. That usually also allows the rock shaft (or 3-point if it has one) to not hold a load up & it will slowly drift down with a rockshaft load on it.. The 3rd is through the power-trol box to rear housing gasket near the pressure port hole.. (same symptoms as #2) There could also be cracks or porosity in the rear castings but those are very rarely found.. Unless you want to re-seal all 3 places or pull the rear housing for nothing I would suggest you first.. Use the tractor for a while with the PTO spinning but no use what so ever of the rockshaft.. If it still leaks the PTO oil out suspect the PTO pump front seal � If no leak found in the above test then place a load on the 3-point (if you have one) & see if it slowly drifts down,, if so replace the rear P/T box to housing gasket.. Then re-check for a slow drift down.. If it still leaks down then pull the rear housing off the tractor & install a new cylinder to rear housing gasket.. Clooney
