4240 PS-leak mystery
GaPlowboy
01-09-2005 07:04:39
My friend bought a nice 4240 Power Shift yesterday. The Hyd pump is leaking, we knew, but there were no more leaks under the tractor while it was sitting in the same place and running for quite some time. It drove out perfect, but after driving the tractor up on the trailer, we saw a nice leak coming from the bottom of the Damper housing where the clutch housing would be if it were a Quad Range. It was not blown back there from the pump by the fan because it would be on the bottom of the oil pan too, and it's not. I can feel an indention in the bottom of the casing where it's coming from. My question for one of the John Deere Mechanics is this: Is this casing supposed to have a small plug there to drain Hyd. fluid? The man selling it said he hadn't saw it before either, and he's ran it for 2 years. I'm going over there today and really go over it good with some dry rags to see if I can find the source.
Thanks in Advance; Gaplowboy
G/MAN
01-11-2005 10:39:59
 Re: 4240 PS-leak mystery in reply to GaPlowboy, 01-09-2005 07:04:39
There should be no oil in the clutch housing on an 8-speed powershift Deere of any vintage, be it a 4020 or 4840. As Bob said, it's likely either engine oil coming from a leaking rear seal or cam bearing bore plug, or a leaking trans input seal. And yes, there is a small hole in the bottom of the housing to allow any oil that does leak to escape. Do make sure that the oil isn't possibly coming from the blowby tube located at the RH rear corner of the engine. That is in relatively close proximity, and could be a source of some oil vapor condensing on the housing.
Gaplowboy
01-12-2005 05:09:25
 Re: 4240 PS-leak mystery in reply to G/MAN, 01-11-2005 10:39:59
Thanks G-man!
Bob
01-09-2005 11:13:26
Probably a bad transmission pump seal. Are you sure it wasn't engine oil from the rear crankshaft seal?
Gaplowboy
01-12-2005 05:08:19
 Re: 4240 PS-leak mystery in reply to Bob, 01-09-2005 11:13:26
Thanks Bob!
