Styled G tire options
billonthefarm
01-08-2005 18:24:47
According to the materials I have late styled G tractors were not available with 13x38 tires. Looking at many vintage pictures in appears to me that these tractors may have had 13x38's. They look good with the larger tires but everything I have says that the largest option was a 12x38. What do you guys think?
DP
01-09-2005 09:38:03
 Re: Styled G tire options in reply to billonthefarm, 01-08-2005 18:24:47
third party image
I really like the 15.5 X 38 on my 49 G. I had the rims widened to 15 inchs back in the 70's, and have run them that way since. I think the biggest the styled G's were available with was the 12 X 38's, which are now the 13.6 X 38's. The unstyled G's can be seen with the 13 X 36's, which are now the 13.9 X 36's Don
BushogPapa
01-08-2005 20:07:47
Most tractors came with as large a tire as was available, in their day...not that they couldn't have used a larger tire..!! It all depends on what you are going to do with it...if showing it only..go for the "Original" size replacement... If you need to USE it, get what it really NEEDS, to be a handier unit for your needs..!! My late JD "B" has entirely too small tires on it, and they are 12.4x38"....leaves too many ruts..!!! I have 15.5x38, 1/3rd Loaded with Calcium-on 14" rims, on my JD "520"--and they are just Perfect for mowing water-ways in low-ground, and for moving snow... I can't even go any larger on my 630, as a tire larger than a 15.5 won't fit in the furrow...!! A "G" would look real good with a set of 15.5x38's on it..!! FWIW...!!! Ron..
Mike Aylward
01-09-2005 16:36:13
 Re: Styled G tire options in reply to BushogPapa, 01-08-2005 20:07:47
Bushog Papa, you could go up to a 16.9-38 tire. They have pretty much the same tread width but a taller cross section. Not original, but they look nice on tractors like yours. Mike
Deeresaver
01-08-2005 18:55:51
My 1952 G had 14.9X38 tires on it when I bought it, they were old and cracked. I checked on new tires the same size and found I could buy 15.5X38 cheaper new. I had a good used set of 15.5x38 6ply. So I bought new 14" rims and put them on. Really like the looks of them. I guess its what you like..Most late styled G"s that I have been around have had 14.9x38 or 13x38 (which I believe are the same) on a 12" rim. Jim from Ohio
Clooney
01-08-2005 18:46:46
Billonthefarm, you�re not confusing the old original 12X38 with the present tires sizes are you ?
When your G was sold the tires were sized differently.. The 12 X 38 at the time your G was sold would be a 13.6 X 38 now..
billonthefarm
01-08-2005 19:06:48
 Re: Styled G tire options in reply to Clooney , 01-08-2005 18:46:46
I understand that a 12x38 became the 13.6x38 and the 13x38 became the 14.9x38 and so on with the 15.5 x38 a new size with no previous match. It just seems that in looking at archive type pictures that many of these G's have what appears to be 13x38 (14.9x38) tires. And yes a 14.9 and 13.6 both use a 12 inch rim. Just wondering what size tires to put on my G.
Clooney
01-08-2005 19:36:53
 Re: Styled G tire options in reply to billonthefarm, 01-08-2005 19:06:48
billonthefarm, I sure don't show anything larger than the 12 X 38 on the G but I haven't ever researched the G for all tire options.. Like you, I have seen a lot of bigger tires on the G so that must have been done at tire replacement time or the selling dealer swapped them out at time of sale.
Maybe Duane Larson can educate us here as he has done a lot of wheel/rim research & maybe did some tire size research at the same time..
Clooney
Duane Larson
01-08-2005 21:40:38
 Re: Styled G tire options in reply to Clooney , 01-08-2005 19:36:53
billonthefarm and Clooney,
I have no information that anything larger than a 12-38 on an 11 inch rim was used from the factory on a styled G. That being said, it was not uncommon to use a tire that is two inches wider than the rim, so a 13" (now 14.9) tire could be used on an 11" rim - so it depends on how close to original you want to stay.
