730 D Clutch Problem
Blake Edwards
01-08-2005 13:34:20
After adjusting the clutch on a 730 Diesel. I drove the tractor for about 30 minutes after the clutch adjustment to make sure it was working properly, and it was working fine, good snap when engaged and disengaged, pulled well. So I shut it off, for about 45 minutes. Then startde it up, but the clutch would not disengage at all. It acted like the adjustment bolts were tightened all the way down. So i cut it off and loosened the bolts and started it up again, but the same happened. I am clueless, any help is greatly appreciated.
Clooney
01-08-2005 13:49:51
 Re: 730 D Clutch Problem in reply to Blake Edwards, 01-08-2005 13:34:20
Blake, many possibilities here..
We really need more information & history on your problem to be specific, so if you can tell us when the problem started, has the tractor been worked on recently before the problem started, has the tractor been stored or sitting a long while before the problem started?
If it�s been working good all along for a long time now & the problem just started I would suspect a delaminated clutch plate disk that has broken & jammed up in the pulley clutch pack (usually the most inner plate)..
If it has had recent clutch disassembly I would suspect the 2 clutch plates with the ears had their holes installed over the adjusting bolts instead of the 3 drive pins..
If neither of the above apply give us more information & we can give you whole list of things to go through�
Clooney
Blake Edwards
01-08-2005 20:07:34
 Re: 730 D Clutch Problem in reply to Clooney , 01-08-2005 13:49:51
The clutch has been recently disasembled. But the thing that I don't understand is I drove the tractor after adjusting the clutch to a garage and shut it off, washed it only, then started it back up within 1 hour and tried to disengage the clutch but it wouldn't budge. I just don't understand how I can drive it one minute, shut it off, then crank it back up and clutch wouldn't disengage. I'm stumped, I didn't tinker with anything between when I shut it off and started it back up. I thank you for your help, Blake
Clooney
01-09-2005 04:12:34
 Re: 730 D Clutch Problem in reply to Blake Edwards, 01-08-2005 20:07:34
Blake, check to make sure you didn't install those 2 eared disks over the 3 adjusting bolts. They go over the 3 drive pins.. If on the adjusting bolts it can cause the clutch to stick (under certain conditions) & especially if the adjusting bolts have some step wear on their sides..
Clooney
