40W Rear Hub Bolts
ET
01-08-2005 12:57:02
Does anyone have any good ideas on getting the hub clamp bolts out? I drilled them out on one side, is there an easier way?
ET
01-09-2005 13:12:48
 Re: 40W Rear Hub Bolts in reply to ET, 01-08-2005 12:57:02
Just thought I would let you guys know I got the hub off. Heat plus air hammer equals broken hub and off it came. I have another one out back on a parts tractor, but it may come off just as hard. thanks for the input.
JerryBird
01-09-2005 05:45:27
I've been surprised at what good quality air hammer will do.Used it to push long broken bolts out of final drives, and the hub bolts you are currently fighting.
BushogPapa
01-08-2005 20:13:03
Sounds like a good time to get out the acetylene torch, and melt the bolts out... If you are careful, you won't cut into the hub... Get them RED first, then "Blow them out"...If you have a "pilot hole" thru them, it is even easier to Blow them out...
Mike M
01-08-2005 14:05:27
Maybe a real good soaking with some penetrant oil and work them back and forth with a large air impact,maybe even some heat.
ET
01-08-2005 16:43:06
 Re: 40W Rear Hub Bolts in reply to Mike M, 01-08-2005 14:05:27
Mike the bolt is suck the entire lenth that it goes through the hub and clamp. The bolt heads are twisted off and I have been filling the cavity with pb blaster and they won't budge. Thanks for the input. Eric
