Power steering on a 720
720
01-08-2005 12:28:08
My 720 seems to have a problem with the power steering. The steering is extreamly easy to almost perfect right after the tractor is started. But after a little time of running not even under a load it gets really hard to steer. Almost as bad as having no power steering.
Thanks
Clooney
01-08-2005 13:17:54
 Re: Power steering on a 720 in reply to 720, 01-08-2005 12:28:08
720, you are probably either looking at a P/S pump that is loosing pressure as the oil warms & thins out or the steering vanes in the lower pedestal leaking & by-passing input pressure. It could be something else but those are the most likely & common..
Both are relatively easy to test for but in both cases are rather a big job to repair..
The pump test is obvious & that takes a pressure gage of around 2000 lbs & high pressure shut-off valve as well as a some fittings to install in the pressure line at the steering bolster top.
The by-pass test is even easier but requires the nose grill of the tractor to be removed & the steering valve to steering vane line(s) removed then steering wheel turned & held to one side while watching for the amount of oil that flows out of the non pressurized side.
Both are in the Deere steering service manual & should be purchased if you are going to work on that steering system yourself.. Without a proper P/S service manual you could cause expensive damage or miss some part of the operation that is necessary.
If that tractor was once good & just started to act up, suspect the above,,, If you purchased that tractor & it hasn�t ever been right you MIGHT try a P/S oil change as it could have some transmission fluid or Deere�s winter P/S fluid in it..
Power Steering Manual __ SM2050
Clooney
Tyler-MO
01-08-2005 20:01:40
 Re: Power steering on a 720 in reply to Clooney , 01-08-2005 13:17:54
Clooney,
Have you ever thought of composing a supplement to JD powersteering systems. I have SM2050 and have read it but it seems that you have quite some experience in this area. I rebuilt my 520 p/s system and it still is not where I want it to be. I know that there going to have some sort of Powersteerig clinic at (the gathering of the green??) sometime soon. I have begun to feel that most of my problems lie in the valve housing (mainly wear), as the forementioned problems are fairly easily diagnosed.
Just wondering...
Tyler in MO
Clooney
01-09-2005 07:05:10
 Re: Power steering on a 720 in reply to Tyler-MO, 01-08-2005 20:01:40
Tyler, you ask,,
Quote:--"Have you ever thought of composing a supplement to JD power steering systems"
--Well! __ Not exactly Deere power steering systems, but after I retire & have less time on my hands than a I do now, I was kind of thinking of maybe writing a comprehensive trouble shooting & service manual on all the 2-cylinder Deere systems that would take a novice to expert completely through diagnosing & repair of the Deere 2-cylinder engine, trans, & sub systems.. All it takes is time- Oh� & me learning to spell better�
If there are things in that SM2050 that you don�t understand & need help with just ask here we can either help you out or confuse you more.. That�s one thing I haven�t ever liked about most auto, truck, & tractor service manuals,, they assume you already know some things you might not as they are usually written with the professional mechanic in mind..
Clooney
720 LYLE
01-09-2005 10:20:20
 Re: Power steering on a 720 in reply to Clooney , 01-09-2005 07:05:10
I love to read the advise according to Cloony, so I would like to be your first customer. Get to it write that manual! Lyle
stubc
01-09-2005 09:50:05
Mr Clooney,
For what its worth, I would for certain buy that type of manual. There is a niche there not filled and a manual of that type would further the hobby for novice and intermediate mechanics.
The Dukester
01-09-2005 15:36:13
 Re: Power steering on a 720 in reply to stubc, 01-09-2005 09:50:05
Clooney, if you ever get that manual written, please make it known on this board, I'm sure it will sell real good. I for one will buy one quicker than a heartbeat. I have several manuals, I and T, and the restoration book, but I bet yours would be far better, you're a true "hands on man".
