1956 JD70D Ignition and light switch
FFP guy
01-08-2005 08:24:55
I need to locate a new one. thanks
buickanddeere
01-08-2005 09:49:18
 Re: 1956 JD70D Ignition and light switch in reply to FFP guy, 01-08-2005 08:24:55
Check the new or used switch carefully. Nothing like finding a spark ignition or 24V diesel switch in your 6V diesel.
F-I-T
01-08-2005 08:38:01
FFP Guy:
JD still carries them (P/N AR2460 R). I have removed the back for cleaning and salvaged some of them, but that depends on your particular problem.
Frank
old bones
01-08-2005 15:06:02
 Re: 1956 JD70D Ignition and light switch in reply to F-I-T, 01-08-2005 08:38:01
f.i.t.- the switch in my 60 is acting up- ignition works, when turning to lights, sometimes it cuts the ignition, sometimes the lights come on, sometimes just the head lights and no rear light, sometimes the dash light. was going to order an aftermarket switch. didn't know they could be taken apart and put back together successfully. had a switch on the combine that i replaced once, and i peeled back the little wrap-around tabs that hold the back in, to see what was inside. are these switches presses together in the same manner?
old bones
F-I-T
01-08-2005 15:17:52
 Re: 1956 JD70D Ignition and light switch in reply to old bones, 01-08-2005 15:06:02
Old:
Yes, just carefully bend the tabs back and you'll be able to ascertain the problem. I've cleaned them with a pencil eraser and some acetone or alcohol.
If you break a tab, you might be out of luck, but my thinking is that it's not's working right now, so what do you have to lose.
Frank
FFP guyf
01-08-2005 12:28:20
Thanks F-I-T, Ive had one ordered thur JD for over 2 months. Just trying other sources, thanks again FFP
F-I-T
01-08-2005 15:14:31
 Re: 1956 JD70D Ignition and light switch in reply to FFP guyf, 01-08-2005 12:28:20
FFP Guy:
My dealer had one in stock as many who sold or serviced two cylinders still do.
I don't think a dealer who can't get that part out of the branch warehouse in two days or under is trying very hard at all.
Frank
