730lp Pos Grd want to change to Neg grd//12 volt
Ben.So.Tex
02-12-2004 17:08:37
I would like to change my 730 to Negative grd, all my other tractors are neg grd... I THINK all I have to do is flip the 2 wires on the amp guage,,,and flip the 2 wires on the coil,, and the generator should remaim the same,,, Correct me if I am wrong. Thanks BEN
Bob
02-13-2004 10:32:47
 Re: 730lp Pos Grd want to change to Neg grd//12 vo in reply to Ben.So.Tex, 02-12-2004 17:08:37
Ben,
It's your choice, but if you decide to switch the ground polarity, in addition to the two changes you mention, you need to polarize the generator BEFORE STARTING the tractor with the battery polarity switched.
There is really no good reason not to make the switch, if that is what you want. Even Mother Deere made the switch a few years down the road from when your tractor was built.
Do you have more corrosion problems on your other negative ground tractors than you do on your 730?
Tom in Mo.
02-12-2004 18:37:55
Hi Ben, I would recommend leaving it positive ground and original. It would be not original for your tractor, a lot of unnecessary work and negative ground terminals corrode more (for reasons unknown to me!) My positive ground battery terminals do not corrode. John T could explain the less corrosion thing.
Just my two cents worth. Tom
Ben.So.Tex
02-13-2004 04:56:42
 Re: Re: 730lp Pos Grd want to change to Neg grd//1 in reply to Tom in Mo., 02-12-2004 18:37:55
Thanks Tom
