Bill, been there done that, got BOTH the T Shirt and a few burns n blisters. The fact that you have some stud sticking out which you can get a hold on sounds promising at least. I have first tried vise grips (or a stud remover tool if long enough) if theres sufficient stud material and then tried to heat NOT THE STUD which softens/weakens it, but the head material next to and surrounding the embedded threads where/if possible, and then tap n shock n hammer (never a hard dead pull) the end of the vise grips to see if she will turn, and then slowlyyyyy yy tap her in then back out then in then back out slowlyyyyy yy over n over and they came out. If you cant get a vise grip or stud remover on, then I first weld a flat washer to the stud which helps prevent welding to the head, followed by a welded nut, then again use shocking hammer raps on the wrench end to slowly milk them in n out in n out. If all else fails, I try to grind the stud top smooth n even to make a good center punch IN THE EXACT CENTER then start with a small bit followed by successive larger bits (the good titanium ones or better) to drill em out n chase the threads with a tap. I dont usually have left hand bits layign around, but they would even be better. DONT DRILL TOO DEEP in case its a head that has pushrod tubes under it. If you have to remove the head, see if your local machine shop can plane/sand/mill the head surfaces where the manifold mates and also the manifold (if you re use an old one) and I also use anti sieze lube (on threads and studs n bolts etc where they pass thru manifold) plus brass or stainless nuts n washers and grade 5 or 8 bolts. If you have good threads n smooth clean flat even polished/milled surfaces you shouldnt have any leaks nor repeat this job in your lifetime?? Best wishes n God Bless John T
