5020 WEIGHT????
Can I
01-06-2005 21:07:11
Anyone know what a J D "5020" weights. It has duals (not the wide tires on the back)It has a cab. Thanks to anyone who can help...
DMont
01-09-2005 08:47:43
 Re: 5020 WEIGHT???? in reply to Can I, 01-06-2005 21:07:11
My book shows the PTO hp to be 141.34 . The drawbar would be about 10% less than the above.
Yes, I do have one that I plan to rebuild. I have found a 6619 engine from a 8640. The engine has been turned up to abut 300hp. I don't plan to "pull" the tractor,just work on a farm and enjoy.
DMont
01-07-2005 16:36:22
I have a tech manual (TM1022) that shows the weights as follows: Standard---15,600 Row-Crop---14,480 Standard--Rear tires--24.5--32 Row-Crop--Rear tires--18.4--38 The above figures are less fuel and ballast.
Can I
01-07-2005 17:20:47
 Re: 5020 WEIGHT???? in reply to DMont, 01-07-2005 16:36:22
Thanks for the reply. Could I get you to check your book to see..... ..... what the draw bar horse power would be..... ..Also it has two batteries under the floor boards are they 6 or 12 volts. I only saw this tractor once and can not remember. If you have one, what can you pull with it? Thanks Again
