4400 compact
onetonford
01-06-2005 19:43:40
Can any one tell me much about these tractors? I have eight acers and a 135 MF now that i use a 5 ft. bush hog. Will this tractor handle this size?
Thanks
Gregg
leon
01-07-2005 04:30:26
 Re: 4400 compact in reply to onetonford, 01-06-2005 19:43:40
Because of the transaxle, I'd shy away from the 42/43/4400 and their 10 Series versions. The 4100 and 45/46/4700 and their 10 Series versions have a totally different transaxle source and design. I bleieve, but am not 100% sure, that the very latest versions of these 42/43/4400 models (Are they 20 or 25 Series?) have a totally different transaxles.
Equally important to model or even brand is thinking your way through the issues of front wheel drive and hydrostatic transmission.
buickanddeere
01-07-2005 08:06:47
 Re: 4400 compact in reply to leon, 01-07-2005 04:30:26
Some of the M4WD 4000/4010 tractors had a light weight front axles that would turn very sharp. Or a beefy axle that had a larger turn radius. The new 4020 series overlaps some of the Yanmar 4010's sizes. It's pretty much US built with a four cylinder Waterloo sleeveless block. They are still toy sized compared to the utility 5105 which sells for about the same price.
Fred G
01-06-2005 20:39:23
I maintain six acres with a 2210 which is quite a bit smaller than the 4400. The 4400 can handle the 5 foot bh very easily. The 4400 has a yanmar diesel and is generally a very dependable tractor. If you'd like to get detailed feedback go to tractorbynet.com and into the John Deere sections and do a search on 4400 or 4410. Important to note, the 4400 was replaced by the 4410 a couple of years ago and a new replacement is in the wings. The 4400 is the highest-powered "mid-chassis" CUT Deere makes, 4500 and up uses the large chassis. Before I bought my 2210 I rented a 4210 for a day, same size with less HP, and was very satisfied with the work I was able to do with an FEL, Backblade and boxblade.
buickanddeere
01-06-2005 20:09:17
Also take a look at the JD 5105. Same money and about double the HP and weight. Most of it's made in the US too.
WayneH
01-07-2005 12:25:53
 Re: 4400 compact in reply to buickanddeere, 01-06-2005 20:09:17
I have a 4400. It was one of the last ones built before the 4410 came out and it has the upgraded front axle. I only have 275 hours on it, but it has worked flawless and has been a dream to own and operate. I normally pull a 15 foot 7 gang mower with it, and it has plenty of power. I"ve used a rotary cutter before, and used the FEL a lot, and never a problem. The only thing I will say, is that unlike the older tractors, these need to be run at 2300 RPM or so to get the rated power, so if you are used to putting around a 875 RPM with lots of low compression torque, you will not be happy.
BTW, I"m looking for a late model B (for me) in the Mid-Atlantic area if anyone has one at a decent price.
Wayne
