DLTX Carb question
Chrisfromsolitude
01-06-2005 19:27:24
I just got my "new" DLTX 71 carb today. It needs rebuilt. I have an old DLTX 33 carb that I broke but I just rebuilt before we had our little diagreement. Can I take the parts out of my 33 and put them in my 71. I think the kits are the same but not really sure. Thanks for any info.
Duane Larson
01-06-2005 21:10:32
 Re: DLTX Carb question in reply to Chrisfromsolitude, 01-06-2005 19:27:24
Chrisfromsolitude,
Some parts are going to interchange directly, and some (like the complete throttle shaft units) will as long as attention is paid to the obvious differences. Interchangeable parts include the needle and seat, float, throttle shaft bushings, load and idle needles, throttle plate, bowl nut, fuel inlet, and maybe others.
Parts that won't interchange include the whole choke system, nozzle (will fit, but designs are different for reasons noted below), economizer plug (33 has one, 71 doesn't), bowl vents, and maybe others that don't come to mind now.
The economizer systems are different as the 33 is for a heavier fuel (distillate, tractor fuel) and the 71 is designed to burn gas. So for example the primary and secondary idle ports are different size in the two carbs, and the economizer systems are different.
old
01-06-2005 20:54:57
My catalog calls for differant kits for those 2 carbs
chrisfromsolitude
01-07-2005 07:27:59
 Re: DLTX Carb question in reply to old, 01-06-2005 20:54:57
Thanks for the help you guys. Think I'll try to swap some stuff today. Thanks again and have a nice day.
