Grey Market John Deere
mike
02-12-2004 16:21:05
HI. Is there any particular reason (mechanical problems or parts availability) to stay away from the Euro John Deeres (like the JD3040 ie US2950)? There seems to be a lot of them over here at fairly reasonable prices. Are parts available thru Canada. Thanks
Adam
02-13-2004 22:05:16
 Re: Grey Market John Deere in reply to mike, 02-12-2004 16:21:05
The tractors are for the most part mechanically the same. The differences come with the lighting packages, weights, and the hitches. Some of the tractors don't have what we consider a normal drawbar. The three point hitches are sometimes different.
Mark
02-13-2004 11:49:43
2120's are showing up around here....around 50 to 55 hp. I know of 3 owners and 2 others sold. The ones of which I am aware were German built. Besides having the x1xx designation rather than the x0xx model they also have all the highway lighting which makes them conspicuous as I am told highway tractor travel in europe is much more prevalent than here. Must use them for cars.
No big problems of which I am aware; sorta like here, they are what their owners made them. I discussed purchasing one with my local green dealer and he said that due to the rub mentioned on this forum, Deere doesn't stock the parts unique to them. I have worked on the neighbor's and they're ok. Problems were minor....to me.
I don't see that as a big deal as we have the www and europeans read this forum just like home boys do..... (beings this site is produced in the USA that makes us home boys).
Mark
McC
02-13-2004 08:45:20
Most of these utility tractors are similar to the US counterpart. There are some subtle differences, but most are minor. On the larger row crop tractors there are more differences than on the utility tractors. Almost all parts seem to be available in the US for these tractors. Be warned that we are starting to see some imported tractors that don't seem to have a US counterpart. Only seen a couple so far. Not sure about the parts availability on these. Hope this helps.
Stan - Florida
02-13-2004 05:03:36
I got a"Farmers Hot Line" magazine the other day that had a one-page article about "gray" tractors and other products. It defined them as "a trademarked product originally designed and manufactured for use in a foreign market that is imported for resale in the United States without the consent of the owner of the trademark". In many cases the problem is with safety features required in the U.S. and not required in other countries.
Do the Mannheim-built tractors fit this category? I would think that Mother Deere would be pretty careful about what she let be sold in the U.S. On the other hand, maybe most of these tractors were not imported by Deere but by international "tractor jockeys".
The real question is, were these generally well-built, dependable Mannheim tractors imported by Deere and Company?
Stan
mike
02-13-2004 06:44:36
 Re: Re: Grey Market John Deere in reply to Stan - Florida, 02-13-2004 05:03:36
Hi Stan
These USED tractors are imported into the US by independent dealers and resellers. Freight on them is usually $3k for a 6 cyl, and $2500 for a 4 cyl....delivered to Los Angeles area. The tractors themselves are usually $8-12k for a late 80's model of under 100HP.
You can deal direct with the dealers in Europe, but they prefer to sell to auctions in TX or Fla to lenghten the paper trail and absolve them from any liability. Generally JD's come from Holland or Ger. The Masseys and Fords from France and UK.
What I was trying to establish with my question is the reliability of the Manneheim tractors....I have heard both good and bad and do not know which models can be considered "headaches"...and to avoid.
Mike
buickanddeere
02-13-2004 00:33:48
Parts are available just as quick from the wharehouse as any other model.Vast majority are identical to US built. The only problem with importing the 20,30,40 series Mannheim tractor into the US. Is the parts counter staff will give you blank looks and suggest you go home and check the model number because it doesn't exist. Same advice applies, buy the manuals from Deere 1-800-522-7448. Tractors built in the 20 through 40 series when the Canadaian dollar was on par or worth more than the US dollar. Can be a deal now as the Liberals have borrowed/spent billions on social progams and devalued the currency.
Joe P.
02-12-2004 17:44:08
I have had a Mannheim 2030 for 30 years. The only problem I have had was the Bosch starter. It didnt last long and was expensive. I replaced it with a Delco and have had no trouble.
JD 5020 guy
02-12-2004 17:19:45
I didn't have problems with either of my JD "grey tractors". They were a 2950 and a 3255.
Tyler--MO
02-12-2004 17:15:29
Mike,
Parts are available from JD here for most recently built Mannheim built tractors. I just sold a scv oil line to a guy for a 3140 Monday. They seem to be fairly good built tractors. I will say that some parts that have to come from Europe..(very few fall in this catagory) may take as much as two weeks. However, most parts are in stock somewhere here in the US. Tyler-MO
