JD 60 Block size
Bobby's toy
01-06-2005 18:10:11
I have a JD60. The block is stamped 6 inch power block. Is this a original or aftermarket block also if it is aftermarket where can I get parts
Zeke
01-06-2005 18:43:16
 Re: JD 60 Block size in reply to Bobby's toy, 01-06-2005 18:10:11
Hinrichs Repair has oversized pistons for your powerblock. Phone # (815)778-1900. When you take it to the machine shop to be bored, tell them that the block has o-rings in it and not to boil it. Search this page and the pulling page for a guy going by WTW and read up. He knows his powerblocks.
Clooney
01-06-2005 18:23:19
Bobby's toy, that block is not original, it came from Tractor Supply Company as a power block.. It is different than the production Deere block as it used wet sleeves & the pistons came out the rear.. It was sold & used as a power enhancement option as it added engine displacement..
Parts (at least new) are very hard if not impossible to find because they are no longer made or sold,, They are in very short supply due to all the tractor pullers buying up all the parts.
If you search long enough you can find some replacement parts (maybe).. Some people just re-sleeve the existing wet sleeve & use a new piston, or re-use the old one. Piston rings can be bought from most ring companies like Otto�s..
Clooney
Bobby's toy
01-06-2005 19:50:19
 Re: JD 60 Block size in reply to Clooney , 01-06-2005 18:23:19
Thank"s a bunch Zeke & Clooney. Know I know where to start looking when I start my rebuild
