2 Cylinder Sound
Bud W
01-06-2005 15:19:30
I'm in the market for a 20 or 30 series John Deere simply because I love the sound the two cylinders make ( my other tractors are AC's and Farmall's-all family hand me downs ).
My question is " do the diesels have the same neat sound as the gasoline engines?
Thanks
donwisc
01-06-2005 18:45:51
 Re: 2 Cylinder Sound in reply to Bud W, 01-06-2005 15:19:30
Your question on JD sounds brings up a suggestion for Kim.. I have heard some JD running on other sites but they leave something to be desired.
How about a section on this site devoted to all the sounds of the different models. Then everone could compare first hand. The best is when they are under load.
Clooney
01-06-2005 15:38:27
Bud W, you ask,,
Quote: --"My question is " do the diesels have the same neat sound as the gasoline engines?"
--Does the 2-clylinder diesel sound like 2-cylinder tractor? Yes..
Does the 2-cylinder diesel sound like a gasoline 2-cylinder tractor? No..
--Does the 2-clylinder diesel have a neat sound? Yes (it�s just different & has a sound of it�s own)..
The 2-cyl diesel has a unique sound but so does the M-430, the D's , the Dubuque 2- cyl diesel, the G, the GP-- they are all different & I like them all..
Clooney
Dubuque 2 cylinder
01-07-2005 13:35:47
 Re: 2 Cylinder Sound in reply to Clooney , 01-06-2005 15:38:27
Why do the Dubuque tractors sound like lawn mowers? Is the the crank different, (both pistons on one journal) or is it the bore and stroke, or the vertical pistons?
Thanks,
Clooney
01-07-2005 13:48:00
 Re: 2 Cylinder Sound in reply to Dubuque 2 cylinder, 01-07-2005 13:35:47
Dubuque 2 cylinder, probably a little bit of everything..
Higher compression, smaller pistons, different cam timing, shorter exhaust travel, sparks every other revolution, lighter flywheel, smaller carb, higher RPM�s, different cyl head shape, smaller valves, different muffler..
The Dubuque�s have a 180� crankshaft just like the larger horizontal Deere�s..
Clooney
