'28 JD-D ... a couple of questions ???
MMB
01-06-2005 14:47:32
Never been on the JD forum here before so here goes. A friend of mine is working on a '28 JD model D and maybe someone could answer these questions:
1. Am I correct in assuming that the valve order (from R to L viewing from the front of the engine towards the operator) is Exhaust, Intake, Intake, Exhaust (exhaust valves to outside, intakes to the inside)?
2. Do the cylinders fire one full revolution (360 degrees of turn) apart from each other?
Clooney
01-06-2005 15:19:55
 Re: '28 JD-D ... a couple of questions ??? in reply to MMB, 01-06-2005 14:47:32
MMB,,
1)- Yes, {Exhaust, Intake, Intake, Exhaust} is correct.. As with most 2-cylinder Deere�s the outside valves are exhaust & the 2 in the center are intake.
2)-No, the actual firing position of that �D� is 180�/540� as Bob stated.. If you are asking for magneto timing reasons the original mag rotated at crankshaft speed but the mag had a 2 to 1 internal gear reduction so only sparked every other revolution on each cylinder.. If it has a replacement later Wico mag it could have a spark on every revolution as some of the later Wico mags rotated at crankshaft speed with no internal gear reduction so sparked each cylinder at near TDC on every revolution..
The old �D� has a 180� crankshaft.. What that means is: when one piston is at the top of it�s stroke the other piston is at the bottom of it�s stroke.. With that 180� firing & 540� of crankshaft coast time - that is what gives those old Deere�s that unique uneven running sound..
Clooney
Bob
01-06-2005 14:54:58
Consider cylinder position from the standard vantage point, which is with you seated on the tractor facing forward.
LH cylinder fires, followed by RH cylinder 180 degrees later. Then the cankshaft will rotate 540 degrees before the LH cylinder fires again.
