3020 Oil Light
Ranhil
01-06-2005 11:58:06
My oil light recently came on on my 3020 gas. Oil was changed a few weeks ago and level is fine. Have not heard any change in the sound of the engine. suggestions????
thanks
4010JW
01-08-2005 16:55:14
 Re: 3020 Oil Light in reply to Ranhil, 01-06-2005 11:58:06
One other thing on a gas burner that can happen is that the fuel pump diaphragm can rupture and you can have fuel in the oil and thin it down to the point where light flickers. You will also have oil-- maybe tooooo much. Check to see that oil doesnt smell like gasoline.
old
01-06-2005 14:08:25
Just another ouick note thats why they are call idiot lights you can't depend on them and I never do, I install a guage and throw that light set up as far as I can
G/MAN
01-06-2005 13:19:42
I agree with old. First check the pressure with a known good mechanical gauge. But more than likely it's a faulty switch or bare spot in the wiring grounding the circuit out. Without looking at the schematic, I'm pretty sure that switch is open when there is oil pressure. When you lose pressure the switch closes completing the path to ground and turns on the light.
old
01-06-2005 12:50:32
Install a guage, senser may have gone out or the pump may have gone south, but with out a guage you can not be sure
Tim Braun
01-06-2005 18:42:47
 Re: 3020 Oil Light in reply to old, 01-06-2005 12:50:32
ya, sounds like oil sender to me, have ran into wiring shorted or some relays by the starter cause light NOT to work as well... and believe me, thats not good!
