870 4wd clutch problems
Frank
02-12-2004 15:45:17
Hello-
I have a 98', 870 4wd, 200 hrs....Now until recently my tractor has been working fine. For the past few days when I put it in any gear the tractor moves slowly until enough speed is built up to get it going. I'm wondering if the clutch is going bad and needs to be replaced or does it just need to be adjusted. Any information will greatly be appreciated.
Mike M
02-13-2004 04:52:40
 Re: 870 4wd clutch problems in reply to Frank, 02-12-2004 15:45:17
I would check the clutch pedal free play first and make sure you have some.Do you have the owners manual ? If so this procedure should be in there somewhere.200 hrs is very low and I would not think it could be torn up yet.
Frank
02-13-2004 08:32:02
 Re: Re: 870 4wd clutch problems in reply to Mike M, 02-13-2004 04:52:40
Thanks...I do have the owners manual and it does show how to adjust the pedal. It's hard for me to think that the clutch is out with only 200 hrs. too. When I let out on the clutch it doesn't seem to revive up like a car use to when the clutch was going out but it takes time for it to move even when I'm in a small rut. Do you know if this usual for the pedal to get out of adjustment or have I done something wrong? Thanks again for your input.
Mike M
02-13-2004 09:53:32
 Re: Re: Re: 870 4wd clutch problems in reply to Frank, 02-13-2004 08:32:02
They do need adjusted from time to time. Maybe your linkage got bent up ? If you have never adjusted one before the free play of the pedal is where it moves very easily then you should feel it contact the throwout bearing. Go by your book but a guess would be 1 inch.You don't need the engine running, stand by the side of the tractor and use your hand to get better feel. That clutch may not be hard to push due to the small size and you may want to unhook the linkage or at least move the adjustment to see if you feel a differance.Something is wrong because it should take hold as soon as released or you will burn up your clutch if ran this way.
