420W engine rebuild or replace? 1st post
Neilho
01-06-2005 07:42:53
Hello all,
I've been reading a lot on this board lately and have got a lot of really usefull information. I wanted better charging, a 12V system for winter starting and electronic ignition, and I found all the info I needed on this board. Thanks! The 420 also needs a rebuild, I believe. It's been an oilburner for all of the 15 years I've owned it but now it's fouling plugs way too often. My questions- Should I buy a rebuilt engine, a used engine or buy parts and do the rebuild myself? What other engines interchange with the 420W? What/who to watch out for? I've never rebuilt one of these engines but have rebuilt several automotive engines and am a machinist so am confident I can rebuild it if necessary, but also think there're some pros out there who'll do it way faster and will know a few tricks I don't and that it could be worth it to have someone else do it. Dennis Polk JD will sell a good running, compression checked 420 engine, complete, for $1800, no exchange. Opinions and sources please.
TIA,
Neil Hochstedler
Vermont
buickanddeere
01-07-2005 08:25:12
 Re: 420W engine rebuild or replace? 1st post in reply to Neilho, 01-06-2005 07:42:53
Can't hurt to get Robert's Carburator to true up the cam and followers. This is the time for fresh distributor bushings too. Doing these and the cam eliminates alot of rough running mysteries. If looking for a little more snort the LP pistons slip right in there. New valve guides will help slow oil consumption and keep the valve/seats surfaces fresh.
neilho
01-07-2005 08:58:52
  in reply to buickanddeere, 01-07-2005 08:25:12
By "truing up the cam and followers" I assume you mean having them reground. I probably wouldn't have thought of that. Would LP pistons raise the compression? I was thinking to have hardened valve seats installed, too...
buickanddeere
01-07-2005 20:52:40
 Re: in reply to neilho, 01-07-2005 08:58:52
Yes maybe even an extra HP or two, yes more HP/efficiency & yes with unleaded fuel.
Neilho
01-08-2005 05:25:15
 Thanks! in reply to buickanddeere, 01-07-2005 20:52:40
With these things, every little bit helps!
neilho
01-06-2005 14:49:53
 Thanks! Where do you buy parts? in reply to Neilho, 01-06-2005 07:42:53
Guess I'll just tear into it. What are your favorite parts sources?
TIA.
JerryBird
01-06-2005 16:30:20
 Re: Thanks! Where do you buy parts? in reply to neilho, 01-06-2005 14:49:53
Yep, open it up and see what you got.As far as a parts source ,I highly recommend Triple G Service .Always good quality parts and great customer service.Thier toll free number is 1-888-720-0830.
JDWayne
01-06-2005 10:29:54
If you can do it I would and then you will know what you got. 1800 is too much for one of those engines.
Thank You Wayne
CPeter
01-06-2005 10:17:58
As was stated by others, you know where this has been for the last fifteen years. If there are no serious sounds from the bottom end of your engine and the block has no cracks, you may even get off with with a rebore and new rings and pistons. Check the bearings, valves and head, but go with what you have. You will be much better off and a lot of money ahead. $1,800 is a lot of money for a used engine. That much will buy a rebuilt short block and head and you should be able to rebuild yous for a lot less than that.
CPeter
Henry J
01-06-2005 10:01:38
Neil
If it was mine, I would pull the head and drop the pan, take out the pistons and have a look at it.
If after measuring it up and it has to be bored, it still won't be that big of a job to complete.
Then you will know what you got plus have at least a grand left in your pocket.
Good Luck
Mike M
01-06-2005 09:46:20
You have had it for 15 years you know what you got. If you get one somewhere else you have no idea of what it's been through and it may be worse than what you have. If you have a good block that holds antifreeze and isn't cracked rebuild it. It sounds like it is long overdue.
Carl NY
01-06-2005 09:29:23
Neil. I would take the current engine apart to determine it's condition. If the block is free of cracks. mic the cyl. A rebore with new pistons , rings & bearings would provide you with a tractor that should operate well as long as you need one.
