Hey dirt, Indydirtfarmer that is
txblu
01-06-2005 07:06:38
John,
Been off for a couple days. Hope your Kidney bruise is ok.
Did what you said to get the 4230's wheels loose and moved. Decided it was too much for one man (getting 3 weights per wheel off and all) so, with your directions in hand,went to a local auto tire and fixup up shop. Had 3 helpers with no other business so had plenty of help. They had blocks, jacks, forklift and 1" impact wrench.
Since the tractor was just painted, the seller had to remove the wheels to paint the cab. Great for me. One side took one whack and the other none. I could see marks on the end of the axle where it had been visited before. Shure seems weird banging on the end of a differential gear/bearing assembly with a sledge. When I told one of the guys to do it, he looked at me like I was nuts.
Rather than a cheater bar (for those reading and thinking) we used his 1" impact wrench. Just a thump thump thump, then over to the other screw and thump thump thump and back and forth, keeping a close eye for any indications of movement; watching to insure that the bolts were rotating (ever so slightly, but evenly) as we whacked and she just walked right off.
I was amazed at how fast the turning gear moved the wheels out.
Really turned out great and I am tickled to death.
Gave them all a $10 tip when finished, for working so hard for me and keeping the paint pretty.
Again thanks,
Mark
Maark
01-06-2005 15:53:17
 Re: Hey dirt, Indydirtfarmer that is in reply to txblu, 01-06-2005 07:06:38
Those three bolts should be torqued to 300ft.lbs.
Mike M
01-06-2005 09:52:19
I hope they didn't use that 1" impact to tighten those bolts on the wedge back up.You may split the castings with too much force on that wedge.Early tractors were worse as they had thinner castings. Best to tighten up in stages and then drive around and recheck them often once seated in you won't get any more on them.
Indydirtfarmer
01-06-2005 08:38:10
The shear mass of the wheels, axles, gears, ect...absorb the impact without so much as a whimper. If you oil everything up well enough, they shouldn't stick too quickly. If you need to do them again, turning the bolts alone, should move the wheels. I've broke a many a rack and pinion loose that way. Never had an adverse reaction yet.
I've watched the best John Deere mechanic i know do the exact same thing dozens of times too. I looked at him kinda funny the first time I saw it done too. Just doesn't seem natural hitting anything with a sledge hammer.....
Glad you got it all worked out. Good to see you FINALLY got the right colored tractor! LOL! John
txblu
01-06-2005 08:49:05
 Re: Hey dirt, Indydirtfarmer that is in reply to Indydirtfarmer, 01-06-2005 08:38:10
Well, that's fine, but how's your health?
Mark
