fluid in tires
JD G GUY
01-05-2005 21:25:10
ive got a styled G with fluid in the tires. one tire is very shot, the tube is poking out in a few places and was wondering how to get the fluid out to replace the tire. is there any way to get it out myself or do i have to pay to have it done? how expensive is it? thanks
lookin4crap
01-06-2005 04:05:01
 Re: fluid in tires in reply to JD G GUY, 01-05-2005 21:25:10
Depends on your plan for outcome. Are you planning on re useing fluid? You can reuse but as stated it is very corosive. I would jack tire off gound, stem up and remove air. Then rotate tire down and remove fluid,then let jack down to remove rest of fluid. If you have an area you would like weeds killed for a very long time that would be a good place. If not you need to put it in a container,large container. It is as heavy out of the tire as it is in so make sure you can move container when done. The fliud is basically a salt base calcium cloride. If you want to reload new tires alot of farmers around here are going to Beet Juice. Not supposed to be corosive. Is this a work or show tractor? That makes a differance too. Why load tires for show, just extra weight on trailer. Make sure once done that you wash every thing down good, then wash again and finally wash one more time. Get the idea.
Jason Z in MO
01-06-2005 06:54:11
 Calcium chloride question in reply to lookin4crap, 01-06-2005 04:05:01
I have some tires I am going to remove the fluid because I don't need the extra weight or rust.
Is it the same calcium chloride the county uses on gravel roads to limit dust?
Around here windshield washer fluid is replacing calcium chloride but I understand it is a little lighter.
looking4crap
01-06-2005 23:17:09
 Re: Calcium chloride question in reply to Jason Z in MO, 01-06-2005 06:54:11
I don't know if it is the same stuff as on the road but I was told it is the same stuff (just liquid form) as what you can put on your house ruff to de-ice it. One time I drain it in my yard (brain fart) it killed the grass for about two years. That's why I said to take it out back and kill some weeds. I am sure this is not the correct way to do it, but look around a hunters salt lick some time. Can't be that bad.
pumper
01-06-2005 02:26:00
If your starting from scratch, and do not have any of the necessary equipment on hand, call the tire shop unless you plan on pumping the fluid out on a yearly basis.
old
01-05-2005 22:19:03
Its not to hard to remove it and even save it to be put back in. First you need the adaptor for the stem, a small pump, I use a drill pump its slow but work well. You also need something like a 55 gallion plastic barrel, metal will work also but will rust out fast. Pump it out and after changeing the tire pump it in or, send me an e-mail and I'll send you a page from a JD manual that tells how to do it all. The manual is for a 1935 B but will work for any tractor. by the way last time I had some one do it for me it cost over $100 plus the tire mounting
