JD 60 Wheel Weights
Flint
01-05-2005 19:09:23
Does any one know how much a rear wheel weight weighs on a 60 and how many I can safley put on with out wrecking the wheel bearings? I have a total of four on now and a friend has four more I could put on. Thank you.
Ken
01-06-2005 23:42:12
 Re: JD 60 Wheel Weights in reply to Flint, 01-05-2005 19:09:23
Flint,
Page #100 in the operators manual states "maximun added ballast (liquid or cast-iron) per wheel-850 pounds". Page #102 states each weight weighs approx. 150 pounds. I hope this helps. Ken
billonthefarm
01-06-2005 18:11:22
A deere weight for a 60 weighs in at nearly 150lbs. I was thinking the o.m. gave a maximum added ballast for the rear tires but it doesnt. I did some checking and a 13.6x38 fully loaded with calcium is a little over 600 lbs and when the 60 was tested at the nebraska test lab they added 747 to each rear wheel. Deere personel always set these tractors up so I would guess that 747lbs or 5 weights on each side is what the people that built the tractor thought was reasonable. For the 620 they added 800lbs on the 70 gasoline they added over 1000 lbs per wheel.
BushogPapa
01-05-2005 19:51:22
I saw a John Deere 720 in "2-Cylinder Magazine"..a JD picture where they wanted to see what it could pull, and it had about 5 FEET of weights on each wheel....!!! I would think 4 on each wheel should be enough...you might have trouble keeping them all tight..
Flint
01-07-2005 07:26:12
 Re: JD 60 Wheel Weights in reply to BushogPapa, 01-05-2005 19:51:22
Thank you to all for your help!
