720 d'sel blowby
Soldier Tom
01-05-2005 18:30:48
I saw on the post below about checking compression through the sparkplug hole. Could work on a diesel also, I rekon, but how could I fashion the fitting seeing as no spark plug holes exist? Is this feasable for a diesel motor or is there another trick I can glean from your wisdom? Yes, it the 720 (7204404) I am still trying to resurect. My daughter calls it the "Dalmation Maker" because anything around it while it runs is covered with black speckles before too long from the PTHHHHT out of the stack. I know it probly needs the ring job. I have the manuals, but that seems like a lot of "into it" for me to tackle (Did I mention it intimidated me?) What am I lookin for, encouragement to dig in perhaps, or somehow to prolong the inevitable without damaging the motor more. We don't use it hardly at all, just a couple times a weekend or so a month. Sorry for the long post
~Walk in peace~
Soldier Tom
Carl NY
01-05-2005 22:20:45
 Re: 720 d'sel blowby in reply to Soldier Tom, 01-05-2005 18:30:48
Soldier Tom. This is a difficult problem to diagnois without being around the tractor, but I would guess your tractor is wet stacking as you say you don't run it too much. Those diesels need to run & warm up especially under load. Starting them up & shutting them down after short periods of time causes the slobbering from the exhaust stack. The tractor needs to have a good work out and bring the engine temperature up. You may have to wait until spring to get out & plow with it.
Clooney
01-06-2005 07:22:10
 Re: 720 d'sel blowby in reply to Carl NY, 01-05-2005 22:20:45
Soldier Tom, when a diesel starts spitting black liquid out the exhaust stack that usually means, either the compression is starting to drop a little, or your fuel injectors are starting to malfunction & spraying larger droplets or drooling fuel.
As far as compression testing a diesel- you can make an adapter from an old fuel injector to use with a compression tester gauge or as a device to allow air pressure to be added for leak-down testing reasons.
The problem with compression testing a diesel is they are high compression pressure & are very dependent on cranking RPM during the test.
If your tractor starts ok & runs pretty decent, you might want to start with an injector test (either a quick & dirty do it yourself on the tractor) or pulling them & sending them out.. Then, if a proper injector spray patterns doesn�t help do a real involved compression test & dig a little deeper..
Clooney
