4020 hydraulics quit
Shaun
01-05-2005 17:36:19
Hey guys I need help!I have a customer with a late model 4020 synchro range tractor.His complaint is that when he mashes the clutch in while moving hay he loses all hydraulics until he lets out on the clutch then everything works normal.I am more of a Ford man and need any advice on this problem.I looked through the archives and found a few posts that talked about the charge pump not turning when the clutch was pushed.Am I chasing a problem that Is normal? Please help! sincerely, Shaun
HaySam
01-06-2005 15:16:50
 Re: 4020 hydraulics quit in reply to Shaun, 01-05-2005 17:36:19
I have had this problem with a 1969 4020 for the last 10 years call me I can tell you what to do 903--826--88--75
Bob
01-06-2005 07:46:47
Loader return oil MUST go to the filter cover.
Any high-pressure return-to-sump will shorten the time the hydraulics will work with the clutch depressed. ALL function return oil needs to be routed to the cooler/charge circuit, 'cause once the oil cooler is drained of reserve oil, it doesn't get refilled until the clutch pedal is released, and the transmission pump comes back on-line.
Sources of high pressure leaks-to-sump could include:
Hydraulic SCV's
Brake valve
Steering valve
Rockshaft control valve (if so equipped)
PTO operating valve
PTO brake piston
I recently repaired one the was loosing high pressure oil to the sump, and acting just like your customer's tractor, and it turned out to be the PTO brake piston had forced it's way right through the brake pad, and had fallen out, allowing the brake apply oil to flow unimpeded into the sump.
With the PTO on, there was no leak, and the hydraulics worked normally, so that's something to check out.
With these Deere closed-center systems, if there is a high pressure leak-to-sump, the component that is leaking will heat up faster than other hydraulic components, so a quick check is to start with the tractor cooled off, start it, and go around feeling the SCV'S, PTO valve, steering valve, brake valve, rockshaft valve, etc..
If you don't find the problem, get a genuine Deere shop manual. It will have detailed procedures to locate the offending component, and full-color hydraulic flow charts.
Shaun
01-06-2005 04:02:52
Gerald J, Could you please try to locate that service bulletin on a late model 4020 side console! I had already been told that there was a service bulletin on this problem but none of our dealers can seem to "find" it when you ask about it.Your help is GREATLY appreciated. Sincerely,Shaun
Gerald J.
01-06-2005 07:09:18
 Re: 4020 hydraulics quit. Late version service bul in reply to Shaun, 01-06-2005 04:02:52
I checked my SB collection this morning that only runs from '68 to November '72.
I found three concerning the late 4020.
SB T69-3 page 3.
Has three items to check:
1. Surge Relief Valve Sticky. The factory changed the valve design to cure that about SN 211,476.
2. "Transmission pump charge valve sumping."
3. Manual bypass valve open. Its opened for single acting cylinders, closed for everything else. I guess its on the remote valve, but those are very different from my older 4020 so I don't know where they might be.
SB T70-10. I didn't note the page number. Long about SN 217859 they changed the plumbing at the separate reservoir and oil cooler with a series connection and apparently a new check valve up front on top in a T. A place to look for a worn out check valve.
SB T71-2 page 3. Gives a procedure to check for leaks. Says with no leaks a certain pressure should hold for five minutes with the clutch pedal pushed.
I suspect there are a dozen more in the years since then. I don't have them or an index to them.
Gerald J.
twopop
01-05-2005 20:13:59
Cobroller is right.if he has a loader,plumb the return from the loader into the filter cover.this will recharge the main pump.
msb
01-05-2005 18:22:14
It depends upon how quickly he loses hydraulics.There is a hydraulic oil cooler that should supply the hydraulic pump when the clutch is disengaged and the charge pump is stopped.So it depends upon how much hydrauiic function is used with the clutch disengaged and how long the clutch is disengaged.Without knowing how he is operating the tractor and mower ,it is hard to tell if there is a problem or not.That has never bben a problem for me the way I have always operated my mower.
It could also be the cooler isn't being charged.
Gerald J.
01-05-2005 18:17:46
The charge pump fills the oil cooler that acts as a few gallon reservoir up front.
In the older (pre SN 201,000, without side console) the problem was a check valve in the transmission. Its cured according to a JD Service Information by converting an elbow to a check valve. Look at the 4020 part of my web page at www.geraldj.networkiowa.com
The later side console 4020 has different hydraulics and the check valve problem isn't there but there is a valve problem, I think at the pump. I do have a service bulletin in my collection about it, but I don't have it memorized since I don't have the later 4020.
The hydraulics should stay with the clutch pedal pushed for a considerable time in either model and should be present as soon as the engine is started.
Gerald J.
cobroller
01-05-2005 19:37:04
 Re: 4020 hydraulics quit in reply to Gerald J., 01-05-2005 18:17:46
I assume he is using a front end loader to move the hay. We plumb in a loader valve and return the oil back to a ported transmission filter cover. The covers are available from John Deere and help cure this problem.
Gerald J.
01-05-2005 20:27:00
 Re: 4020 hydraulics quit in reply to cobroller, 01-05-2005 19:37:04
Yes, the ported transmission oil filter cover is the correct place to return flow from the loader, but there are those known problems with the hydraulics of the two versions of the 4020 also. I had the worn out check valve in my 4020 which I fixed by the service information and with loader it keeps hydraulics for a good period after pushing in the clutch. Later 4020 showed the same symptoms but had a different cause.
Gerald J.
S. Thorsen
12-29-2005 17:57:28
 Re: 4020 hydraulics quit in reply to Gerald J., 01-05-2005 20:27:00
I have a similiar problem.
After troubleshooting I have narrowed it down to the differential lock. When I engage the differential lock, I do not lose hydraulic oil pressure when the clutch is pressed. It holds at about 2300-2400 pounds.
Tap on the brake pedal and the pressure drops immediately. Press down on the clutch without engaging the differential lock and it takes about 35 seconds before I loose pressure.
With the differential lock disengaged, I can hear oil passing through the line.
So could my problem be with the differential lock's check valve or is there an internal problem? If the problem is only with the valve or check valve, how is the oil getting to the sump?
Could there be a leak in an internal line or a piston blown?
