H oil pump
jr55
01-05-2005 12:46:35
Can you take apart the oil pump on a model H? I have it out and it's stuck. This tractor has'nt been run in awhile.
Walter Squires
01-05-2005 13:04:30
 Re: H oil pump in reply to jr55, 01-05-2005 12:46:35
Yes, I just did one last week, not much to them, the top gear that runs off the cam can be pressed off the shaft, don't loss the wodruff key(like I did) it's not availaible through JD anymore. Cut the wire that goes around the screen and remove it so you clean everthing good. Take the pressure regulating valve apart and clean it good, I completly disassembled everything boiled it out in muratic acid, bead blasted everything and repainted it with JD buffprimer sealer.
Mine had been sitting so long that everything was all gumed up, you can get the gaskets from JD or cut them yourself, my e-mail is open if you need anything
Good Luck, Walter Squires
