JD 2440
ENG222
01-05-2005 11:06:37
I HAVE A JD 2440 that i have just purchased. The high low gear shift is not attached to the transmission, and it comes out. Is there some type of keeper missing, or do i have other problems.
Also the previous owner said that when the tractor is ran for a cople of days that there is a skim of oil showing up in the anti-freeze.
I don't want to put much more money into the tractor. Should I cut my losses and sell, or try to fix it up.
Also about what is this tractor worth. It has A JD 145 loader, 3600 hours, it is a utility tractor, it apprars to be in good shape.
Thanks for any help.
John
David in MD
01-06-2005 07:44:40
 Re: JD 2440 in reply to ENG222, 01-05-2005 11:06:37
$6000 seems like a good price for a relatively low hour 2440 with loader which should allow you some room to make repairs and still make money.
I fixed the same shifter problem on my 2030. The top transmission cover where the shift levers connect is aluminum and tends to wear. On mine I replaced the cover, the keeper, snap ring, and boot to solve the problem. It seems that the hi/low/reverse/park lever requires more force to shift and wears more than the gear lever.
T213R
01-05-2005 16:57:12
How much did you pay for this tractor?
What year is this tractor?
What other equipment does it have? (Flattop fenders or clamshells? ROPS?, Dual remotes?, what size tires? (mine has 16.9x30s) Is the loader independant of the rear remotes and has it's own separate spool? Low Orchard type exhaust or upright?)
ENG222
01-06-2005 06:02:09
 Re: JD 2440 in reply to T213R, 01-05-2005 16:57:12
Here are the features of the tractor:
Clamshell Fenders
ROPS
Single Set of Rear Remote Hydraulics
16.9x28 rear tires
Loader is plumbed into the front of tractor, and is independant of rear hydraulics
Low Orchard typr exhaust
Thanks for your help
ENG222
01-06-2005 06:03:37
 Re: JD 2440 in reply to ENG222, 01-06-2005 06:02:09
The owner said 1979 or 1980
I paid $6000
