Deere 2750 Head Gasket Problem
scgolden
01-04-2005 18:02:29
I have a JD 2750 that I have owned for about 2 years. Shortly after purchasing the tractor it blew a head gasket. I took it to a reputable shop and had it repaired. 6 months later it blew again. same shop repaired it again, did I mention they sent the head out to have it checked. 6 months later it blew again, this time I changed it myself and did not sent out the head. 50 hrs later it blew again. after much discussion with different people I decided to invest in a brand new head from Deere.... $1200.00... thinking this would surely solve the problem. 125 hrs later its blown again! The last time I changed it I checked the top of the block to be sure it was flat, checked liner height, replaced all head bolts, used genuine deere parts ( maybe thats the problem )torqued the bolts to the required settings, after the initial torque I plugged in the engine heater , let the motor warm up and retorqued.
The gasket has always blown on the back cylinder ( next to cab )but not always in the same place. The second time you could head the compression leaking out, all other times it has gone into the water jacket and blows out the antifreeze thru the cap & overflow.
I am fresh out of ideas and its way to expensive to continue on my current path.
Any suggestions would be greatly appreciated!
Thanks!
Tom
Jonathan in MA
01-05-2005 17:09:58
 Re: Deere 2750 Head Gasket Problem in reply to scgolden, 01-04-2005 18:02:29
Another thing to check ...the dowel pins in the block..they are what holds the gasket in the correct position. I've seen lots of them corroded to the point of almost not existing. They are replaceable...theres a trick to getting them out...thay should fit tight inside the hole in the gasket. Thats a major cause of head gasket failures ...and one of the very few causes in that size engine...not a common problem at all as one of the other gents stated...
buickanddeere
01-05-2005 11:14:36
It's rare but good to see that you understand fastener torquing is a science. Most people just put a wrench on there and reef her down a bit. I had a brief practical course in a shop with stress detection and digital read out on each stud.A real eye opener. In short anything can go wrong from a hard or soft fastener, galling nut to head contact surface, thread length/production tolereances, torque wrench out of spec, casting flexing, dry or different types of thread/bearing surface lub etc. Unless torquing in steps of about 5 lb ft in proper sequence. It's impossible to even get close to even torque. Normally everything is over engineered with a fudge factor and gets by fine with a fastener her and there doing little and others over stretched. Best torquing is all fasteners can be torqued simultaneously. As previously stated there could be something hydraulically locking that #6 cylinder. Or even something stuck in a cooling passage as a long shot. The 329 is used allot around here in the 3130,3140,3150 & 3155's etc.Boringly reliable.
J. Schwiebert
01-05-2005 06:44:30
About 10 years ago I ran into a similar problem. Iwas connected with Victor at the time. We sent 2 of the failed head gaskets back to them for evaluation. When the deal was all done come to find out the torque specs and the bolts being used did not match. The head was actually being overtorqued!
jdemaris
01-05-2005 06:10:30
That engine series was not prone to head-gasket problems. The few that I had to repair as a Deere mechanic had external leaks, not internal or compression related. In fact, there were many that I repaired in field, under poor conditons, no retorquing, no new bolts, and no problems. This usually happend when an injector was stuck, so the head got pulled to drive it out. That being said, obviously you've got a problem. Assuming the mech. specs. have been checked correctly, i.e. and e.g. sleeve standout (or recess) and trueness, block deck and cyl. head surface - have you closely inspected the trouble area for any sort of liquid intrusion? Liquid will not compress . . . so if it gets into the combustion chamber, and the piston comes up on the compression stroke, something HAS to give. I've seen engines that bent connecting rods due to this "hydrostatic lock" situation. Usually caused by an injector stuck wide open, or a small crack or pinhole in the sleeve.
scgolden
01-09-2005 13:43:04
 Re: Deere 2750 Head Gasket Problem in reply to jdemaris, 01-05-2005 06:10:30
Thanks for the help with my problem. I have a question regarding the liner being possibly cracked. How can I check to see if that is the problem, or if I think thats the problem just go ahead and replace the liners & pistons? can I repace the liners & pistons without breaking the tractor? What all will be required for this job?
Thanks greatly for the help! Tom
twopop
01-04-2005 19:04:27
have you had the #6 injector checked.that is if the injectors were put back where they came out of.
