6V Battery trickle charger
Larry D.
01-04-2005 17:21:42
Hey Guys...Question for Electronics Gu-RU's Will a 6 Volt 150MA Wal-Wart charger (Plugged into A.C.) EVER Hurt a 6V Tractor battery, Connected Continuously... Meaning to OVER charge..Thanks Larry
Clooney
01-04-2005 19:05:55
 Re: 6V Battery trickle charger in reply to Larry D., 01-04-2005 17:21:42
larry, it really depends on the voltage it's putting to that battery�. A battery really doesn�t like to receive a continuous charge at a higher voltage.. The best chargers drop the charging voltage back to about 12.6-13 volts to kind on maintain but not charge, then kick up occasionally to higher voltage to charge, then drop back to maintenance voltage again..
Will it hurt the battery? Possibly if allowed to run long enough but probably not for a few weeks.
Let me say this: I personally wouldn�t do that with my battery(s)..
I use a series of smart chargers that watch the battery�s charge condition & kick in only when needed. OR, for some of my batteries I hook trickle chargers to the barn lights & they charge for a while every time I turn the barn lights on..
Clooney
andy b.
01-05-2005 08:58:28
 Re: 6V Battery trickle charger in reply to Clooney , 01-04-2005 19:05:55
Clooney,
is there a danger of the batteries discharging through the charger if it is connected to the batteries and not powered up? someone told me this once, and i make sure never to leave the charger connected unless it is plugged in and running, but i don't know how true the statement was. i realize the transformer in the charger has some additional circuitry to convert from AC to DC, but i didn't know if it was enough to prevent the battery from feeding back through the transformer. on a fancy-pants new digital charger this probably wouldn't be an issue.
just wondering.
andy b.
JDClooney
01-05-2005 11:51:24
 Re: 6V Battery trickle charger in reply to andy b., 01-05-2005 08:58:28
Andy, you ask,,
Quote:--� is there a danger of the batteries discharging through the charger if it is connected to the batteries and not powered up?�
--That is very possible IF the battery charger is an older one or not originally sold as a battery charger.. Most of the smaller ones I have had experience with don�t feed back as they convert A/C current to pulsed D/C current so have a series of diodes or rectifier in them.
It sure wouldn�t hurt to use a small light bulb or voltmeter to check before using one like that, or placing a diode in the B+ wire between the charger & battery.
That 150ma charger mentioned above could be a power supply or answering machine power supply, or cad battery charger (most chargers that small are for uses like that) & there is a possibility those don�t have a good clean anti reversal circuit in them.. They might not even have a good voltage stability while charging into a lead acid battery load.
A good rule to live by is: if in doubt or you suspect something do a quick test to confirm or nay your suspicion before using .. That way you get no nasty surprises.
Clooney
John T
01-04-2005 18:49:01
Larry, without knowing the exact specifications of that Wal Mart charger, I wouldn't bet my life on this, but if its indeed only a 150 ma charger, like Frank, I SERIOUSLY DOUBT IT WILL EVER HARM THAT BATTERY. Just setting (dependant on state of charge n temperature and other variables) theres some natural leakages n discharges going on in a battery due to chemical reaction, and I dont see 150 ma hurting it. The cheaper the charger, however, (and I bet that Wally World unit is a super cheapo) the less over charge protection built in.
A guess onlyyyyy yyy absent any exact specs
Good Luck n God Bless
John T
Larry D.
01-05-2005 13:21:14
 Re: 6V Battery trickle charger in reply to John T, 01-04-2005 18:49:01
Itis a Wal WART, As in Plugged into the 120v AC Outlet...It's not a REAL Charger, i jusrt htought it would Put a small Charge to keep the Battery from 'Leaching' or letting the wiring drag it down.
John T
01-05-2005 15:43:26
 Re: 6V Battery trickle charger in reply to Larry D., 01-05-2005 13:21:14
Larry, if its simply one of those small plug in 6 to 6.3 volt (or whatever their voltage is???) power supples that work as a substitute for say 4 C or D or AA cell batteries or for kids toys or small electronic devices, ALL BETS ARE OFF.
First of all, I cant even be sure it will even rise sufficiently above the battery voltage (theoretically 6.3 if charged) to charge it any at all.
Second, its a cheap unit and probably has no sort of protection or regulation such as a REAL battery charger which (if a good one) reduces its voltage when the battery becomes charged to prevent overcharging.
The only way to tell would be to hook it up in series with an ammeter and actually see if it pumps any amps through the battery and once its charged see what it continues to do.
Still, if the max amps it would or could ever pump throught the battery were indeed limited to 150 ma, I dont see it EVER harming or overcharging the battery. BUTTTTT T I wonder if it rises sufficient in voltage and has the capacity to pumnp any throught the battery at all??
Try it using a series ammeter n let us all know maybe.
John T
F-I-T
01-04-2005 17:46:05
Larry D:
My guess is....probably not.
But it's only a guess.
Frank
NEsota
01-04-2005 20:46:41
 Re: 6V Battery trickle charger in reply to F-I-T, 01-04-2005 17:46:05
Three ways to bring damage to a battery by overcharge are; (1)A strong charge that causes the bubbles to wash the active material from the plates. (2)A strong charge that heats up and warps the plates. (3)A charge that boils off the electrolite to the point that the plates are no longer covered.
John T
01-05-2005 05:35:33
 Re: 6V Battery trickle charger in reply to NEsota, 01-04-2005 20:46:41
Good summation of potential causes of battery harm. If the charger is well regulated and does reduce voltage as necessary and limits charging current to 150 ma, I dont see it as harmful, HOWEVER, a cheap charger probably isnt well regulated like a more expensive electronic controlled unit and could eventaully cause slight overcharging dependant on the amount of time and the overall state of the battery I guess????
John T
Gerald J.
01-05-2005 14:03:11
 Re: 6V Battery trickle charger in reply to John T, 01-05-2005 05:35:33
Several years ago (maybe longer than that) I picked up a Radio Shack wall wart that was supposed to be a nicad charger for a 12 volt battery. ON it, it says its 17.4 volts and 50 milliamps. Connected to the 12 volt battery in my JD 112, it put out a lot more current (and heated), so I put a pilot lamp in series with it. I think a #47, and then found the current limited to 50 milliamps reasonably well. I used that on my JD-112 with the tiny garden tractor battery for a few years and during that time achieved 3 years of battery life instead of the normal one year (with cheap batteries). Eventually, that Tecumseh died the way of all Tecumseh with a thrown rod and the Briggs that sits there now has only a recoil starter. That last battery is now scrap, I'm sure.
The 50 milliamp continuous charge didn't seem to dissociate the electrolyte rapidly (it really doesn't boil though it bubbles), but did triple the battery life.
With no battery, the cost of mowing has gone down; even more since the Briggs engine runs on 1/4 the fuel the Tecumseh took for the same power.
Gerald J.
F-I-T
01-05-2005 15:28:37
 Re: 6V Battery trickle charger in reply to Gerald J., 01-05-2005 14:03:11
Gerald: I've used that lamp in series myself to regulate a power supply.
I have been using a "Battery Tender" brand on my 6 volt batteries, and it works very well at keeping them up without any electrolyte drizzle that often collects on the tops of pulse charged batteries. It's a decent little unit and you can let it on 24/7 while it maintains a proper flaot voltage. I have never noticed any above normal water consumption, either.
Frank
