720 pops out of 4th gear only
Lyle MN
01-04-2005 17:00:40
I have a 720 that will pop out of 4th gear after pulling for a short period of time. Any ideas where to start to fix this problem. Thanks
Clooney
01-04-2005 18:36:31
 Re: 720 pops out of 4th gear only in reply to Lyle MN, 01-04-2005 17:00:40
Lyle, that depends on what is popping out when it jumps out of gear? Does the shift lever move out of the gate slot or does the lever stay put when the trans just quits pulling? That will tell us if your problem is the under/over drive or actually 4th gear jumping out of gear..
-Without knowing the above information the below is just a general 720 trans problem check out..
-Probably the place to start is by pulling the trans top cover & checking the trans interlocks for operation & locking correctly.. Then check the trans top & bottom shafts for loose bearings by using a long screw driver or bar & trying to move the shafts in all directions.. Loose shafts means loose or worn bearings.
-Then to go farther in & look for loose gears on the splined shaft & look closely for twisted splines on the splined shaft..
-Then pull the trans apart & look for worn bearings in the counter shaft idler gear {common on the 720 with lots of use}..
What I usually find is worn trans bearings or worn input shaft bearing & sometimes worn gears on the sliding splined shaft.. I usually also find worn bearings in the counter shaft idler gear if the trans is a high hour trans or has been run with water in trans..
Those 720 transmissions are a pain to work on & some bearings are getting hard to come by (like the counter shaft idler gear roller bearings).. If a bearing says �New Process� on it expect a problem finding it.
There are many causes of that trans popping out or 4th & about all you can do is pull the cover & start looking..
Clooney
Lyle MN
01-05-2005 03:08:32
 Re: 720 pops out of 4th gear only in reply to Clooney , 01-04-2005 18:36:31
Thanks Cloony for the advise. The shift lever moves over when it pops out of gear. If you keep your knee on the shifter it will not pop out. Lyle
JDClooney
01-05-2005 07:40:19
 Re: 720 pops out of 4th gear only in reply to Lyle MN, 01-05-2005 03:08:32
Lyle, then that means the overdrive part is ok & your problem is more than likely either the shift interlock not holding or 4th gear walking on the splined shaft.. Loose trans shaft bearings could also a cause but those usually allow overdrive walk-out also..
Make sure 4th sliding gear is full engaging it�s drive gear & make sure the 4th gear shifter interlock is working & holding.
Also make sure the shifter & shift lever parts are not so worn that they won�t allow the shifter to move the shift fork far enough to allow interlock engagment
Clooney
