installing decals
4430deere
01-03-2005 15:16:18
i am restoring my 4430 and was wondering if anyone could give me some info on the best way to put the decal around the hood. looks like it is going to be a pain to put on as long as it is. any help is greatly appreciated.
FiremanMike
01-06-2005 17:07:32
 Re: installing decals in reply to 4430deere, 01-03-2005 15:16:18
NO HOLES!!! If you have not yet done this, time to do it right. Any good auto paint supply house carries a spray product that is used to set the decals. Very similar to the soap and water process mentioned but without the film and bubbles soap leaves behind. Yes, use a small squeege and the spray and the decals go on very easily. Make certain the metal is clean, grease free and warm is good. Apply the sprayaccording to the directions and with a little time and effort the decals look professional. Mike
stew
01-04-2005 11:43:08
do they come in one piece ? I just did a 4455 and they were in two pieces per side still it works best if you have 2 people , 3 is even better !
JDBert
01-04-2005 09:35:33
If they came in a box rolled up lay them out with some thing weighting the ends down and put them somewhere warm or in the sun, this will help a bunch. You can poke holes in them if you get air under it, but I just leave them and let the air come out by itself. This might take alittle while depending on how warm it is.
I Bleed Green
01-03-2005 17:41:29
First of all, have the tractor inside out of the wind. Have someone help you if you can. If air gets under the decal, use a pin and make a very, very small hole in the decal where the air is, and then work the air out.
danielgillespie
01-04-2005 16:45:27
 Re: installing decals in reply to I Bleed Green, 01-03-2005 17:41:29
what i do is use water with a drop of dawn dishdetergent to break the water tension then just apply and use a flat plastic putty knife to smooth out work air bubles to the surface when water dries decal is in place
