Dead 3010?
fredburgess
01-03-2005 15:08:11
My buddy at work (near Watertown, NY) just had an "autopsy" done on his 3010. Apparently the previous owner chewed up the brakes, then removed a screen, allowing metal bits througout the hydraulics. Seems the best thing to do is part it out since there is evidence of metal bits throughout the hydraulics. Anyone interested in a good solid running (gasoline) engine or other parts? Alternatively, anyone happen to have a 3010 less engine for sale?
Thanks!
JDBert
01-04-2005 09:44:09
 Re: Dead 3010? in reply to fredburgess, 01-03-2005 15:08:11
I would first drain the oil and get all the "big" chunks out of the bottom of the case. Then I would put the screen back in put in diesel, run it for a little bit, drain it and change the filter. I might even do this twice, then go with a 50/50 blend of diesel and oil run it some more and drain and change filter. I'd then cut the filter open and see what its catching, if its still getting a fair amount of filing in there do it again and then go with new oil and new filter and remember to change filter often. It might cost him alittle bit in oil, diesel and filters, BUT would probably be better then whole saleing the tractor.
msb
01-03-2005 20:43:26
Too bad its too far for me.Its not that big a deal to fix the tractor if you don't have to pay some of these high shop rates today.Is there a young mechanic with more time on his hands than money in his back pocket near you?Granted every hydraulic component would need going through but that would be better that having a bunch of parts setting around.Give a young person a break and see if it comes home to you.Maybe set a low ball price on the tractor and let him deduct the cost of parts or something like that.Trade school near you maybe? Just a thought.
fredburgess
01-04-2005 08:18:55
 Re: Dead 3010? in reply to msb, 01-03-2005 20:43:26
Thanks - yes, if this were mine I'd just go through it over time and save the thing. It's not though, and I know for a fact that the current owner is too busy to tackle it (he works for me...!). Mechanic who tore it down is very reasonable but still of the opinion that it's not worth saving given amount dispersion of metal he's found so far. This machine has brand new rubber on it too. Heck, maybe I'll buy it myself.... Anyway, it's available if someone is interestd. Cheers all.
