1 12v or 2 6v batteries
farmerboybill
01-03-2005 12:37:51
I went to the dealership to buy the intake gasket and, since I was there, asked about some batteries for my 60. He dug up the book and told me they originally came with 2 6v batteries hooked up in series but most people went to 1 12v in the interest of cost. He says I'd get more cranking ability with 2 6v batteries but I really didn't need it. Anyone mess around with two batteries or can think of a reason for me to go this way? The tractor currently has a shot Farm & Fleet 12v battery in it.
philmycrackin
01-04-2005 09:45:33
 Re: 1 12v or 2 6v batteries in reply to farmerboybill, 01-03-2005 12:37:51
two sixes have twice the cranking power than one 12. I have an old A and she starts alot better on the two sixes. Don't mess with someting that works!!!
buickanddeere
01-05-2005 11:34:38
 Re: 1 12v or 2 6v batteries in reply to philmycrackin, 01-04-2005 09:45:33
If anything one 1000CCA 12V battery will can deliever more energy to the starter than two 6V 1000CCA in series. The two 6V may crank longer if they weigh more than the 12V. Who ever counted on cranking for four minutes instead of three minutes?
jgc
01-03-2005 19:09:22
In addition to the other comments, another nice thing about a single 12 volt battery is that there are two less connections exposed to the elements. If the cable connecting the two 6 volt batteries has crimp-on terminals, there are four fewer connections exposed to the elements.
Every connection is a point of failure. - electricity 101.
JGC
Clooney
01-03-2005 16:33:06
farmerboybill, you say,,
Quote:--"Anyone mess around with two batteries or can think of a reason for me to go this way?"
Only one reason I can think of & that is if you are building a show tractor & want it to be original.. Those twin 6's are harder to keep charged when stored & if one goes bad it is harder to install just one battery & keep the system even..
A single 12 is a good plan & will work just fine.. One thing I can recommend when using one 12 volt battery is first get a plastic boat battery box & mount the battery in that (you can leave the top off) That will keep all the acid & other battery mess in that plastic box & keep the corrosion out of the metal tractor battery box.. The other thing I will highly recommend & that is to firmly fasten that battery down.. An automotive battery doesn�t like to be jounced around & securely mounting it will increase it�s life..
Clooney
John T
01-03-2005 16:17:52
Bill, if it were mine I would install a single 12 volt heavy duty truck n tractor battery rated near the 1000 CCA range. Thats cheaper n simpler than the two sixes and will crank her about as well or even better than two of the six volters sold in her day. Unless its extremely cold and the engine n ignitions in poor condition, probably even a 750 or so CCA even would do the job, but them 1000 or 1050 CCA just spin em a bit better, ESPECIALLY if extremely cold.
The more lead n acid n plates you squeeze into the battery compartment, the more energy you can store, and that usually corresponds to more physical size n weight. Thats why years ago the two sixes in series, which filed the box, stored more energy n cranked em longer than a single smaller 12 which, having less acid and plates, couldnt match. However, its possible with todays batteries to get a single super heavy duty 12 that could outperform two lighter dusy sixes of years ago.
If you wanna go all out n moneys no object, those new spiral cell Absorbed Glass Mat (AGM)batteries like Optimal makes store even more energy in the same size, but a 750 to 1000 cca regular lead acid battery will serve you well,,,,, ,be cheaper than two sixes,,,,, ,,plus with the two batteries one could go bad and you gotta spend more money again.
It will be fun to hear other opinions, but I say go with a single 12 volt heavy duty truck n tractor battery at least 750 up to 1000 CCA. NOTE its important to lash the battery down tight so she dont slide around n bang n shock n bump which can shake lead material off the plates that settles to the bototm n may short out.
Good luck n God Bless
John T in Indiana
Brian F. Williams
01-03-2005 16:13:39
We I was a kid, Dad farmed with a 720 gas and a 520. We only used 1 12 volt battery in each. I think in the 50's, 12 volt batteries did not have the cold cranking amps they have today. 1 12 volt battery was plenty in the winter here in Ohio. Just my opinion.
