A Few R Questions
Leaky_R
01-03-2005 05:53:38
Got a few questions about the R
- Someone posted a while back that the torque spec for the pony head is 20 ft-lbs. At that, the heads almost flap in the breeze. Is this spec right?
- I've got sparks coming out the pony exhaust, particularly when I shut the fuel off and she's winding down. What the heck are these sparks from?
- What's the correct water level in the rad? Should it be over the top of the water pipe coming from the pony?
Thanks!
DRL
01-03-2005 17:59:07
 Re: A Few R Questions in reply to Leaky_R, 01-03-2005 05:53:38
I'm no expert by far. Purchased my R this last fall, and am still learning. According to the I&T manual, the torque for the head nuts is 20ft.lbs. Remember, this is a flathead engine, and you want to be very delicate with those heads. Sparks out of the exhaust is just as others have said, probably carbon off the pistons, head or "muffler" coming loose. The water level should be above the pipe coming into the pony. As far as the oil leaks go, not sure. It sure sounds like the rear seal is still leaking. Was there a groove in the crankshaft where the seal rides? Possibly not getting a good seal there. Did you use the copper washers under the bolts that hold the pony onto the main engine? Some of those bolts go through the pony crankcase and will allow oil to bubble out if not sealed with the washers. Does your oil drain plug/bolt have the o-ring gasket on it, or does it seal with a coppper washer? Mine has the o-ring and had to be replaced in order to seal the top of the plug. Have you checked to see if the pony breather is plugged up? If it is plugged with crud, mud dauber nests, etc, will suck oil out of the breather into the carb. If you haven't gone there yet, there is a good website on the two cylinder diesels. If I can get the link thing to work, it will appear below. Good luck.
Bob M
01-03-2005 16:59:27
With regard to the sparks in the pony exhaust, a buddy of mine has a couple R's and both pony's will throws sparks on occasion, especially on shutdown. It's bits of burning carbon blown out of the combustion chambers and exhaust piping. This happens primarily when the pony is suddenly unloaded and as the fuel mixture leans out on shutdown. The resulting rapid changes in temperature of internal engine surfaces (piston top, head, exhaust valves etc.) breaks loose carbon buildup and sends it out the exhaust.
Sorry I can't help with your other questions - though 20 ft-lb for the pony head studs sounds too little to me too!
Leaky_R
01-03-2005 10:20:45
Sorry, one more question:
I rebuilt my R's pony because it was leaking a lot of oil from what I thought was the rear oil seal. I remounted it with new gaskets and seal, and it's still leaking oil - a lot. I read in a previous post that it could be the result of blow-by from the diesel, but I never actually got the diesel going, I only motored it for a while. Here are the symptoms: 1) Oil appears around the base
2) Lots of oil in the pony flywheel area
3) Oil level in the pony seems to be rising
4) The pony's carb is coated with oil on the inside
5) Pony runs pretty good, but starts to die after about a minute
Any help is really appreciated....
