Fairbanks Morse RV2 Mag
Jason Z in MO
01-02-2005 20:20:28
I got a friend looking for a coil to fit his Fairbanks Morse RV2 mag.
Any suggestions?
Jason
old
01-02-2005 22:37:44
 Re: Fairbanks Morse RV2 Mag in reply to Jason Z in MO, 01-02-2005 20:20:28
Don't know what part of MO your in but there a guy around Joplin that rebuild mags. go to magneeders.com to get more info
Duane Larson
01-02-2005 21:44:58
Jason,
You have a couple of choices. I have normally modified a coil from a Fairbanks FMJ mag - nothing too difficult. But the best solution is to replace the coil with a correct new one. A friend of mine who is a coil winder has just started winding them and claims they are as hot or hotter than the original (which the FMJ coil is not - I can verify that). I haven't tried one yet. The correct coil is higher priced, though. You might be able to get by with the FMJ coil if the magnetic rotor has been replaced with an AlNiCo rotor - not uncommon - as it produces a stronger magnetic field.
Jason Z in MO
01-03-2005 11:31:50
 Re: Fairbanks Morse RV2 Mag in reply to Duane Larson, 01-02-2005 21:44:58
Duane,
Thanks for your suggestions, I will pass them along. How do you identify if the rotor has been replaced with an AlNiCo?
Jason
Duane Larson
01-03-2005 12:18:41
 Re: Fairbanks Morse RV2 Mag in reply to Jason Z in MO, 01-03-2005 11:31:50
Jason,
The easiest way is by the appearance. The older rotors with chrome magnets are longer parallel to the shaft, extending basically all the way to the rotor gear, while the AlNiCo rotors are much shorter and there is between 1/2 and 1" open space between the end of the magnet and the rotor gear. Or, if you happen to have a magnetometer or Hall Effect probe laying around....
